Autonomous Wireless AP blocking multicast
Stephen Broix
Community Member
I have a small lab with one wireless AP (Aironet 2600 autonomous) which is connected on a switch without particular configuration. A streamer is connected on this switch and stream a video flow on broadcast.
When I connect a computer directly on the switch, I can access my stream video but when I connect to my network by Wi-Fi, I can't access this stream video.
I've seen on configuration guide that by default the wireless AP block all multicast data with igmp snooping. I disabled it, but it doesn't work anymore.
Is anyone can help me??
Thank you for you'r answer.
Regard,
BROIX Stephen
Viten Patel
hi are you using the latest code?
is this a single vlan setup on wired/ wireless side?
