Autonomous wireless bridge on WLAN with RADIUS
Justin Clark
- I have a WLC5508 running 8.5.140.0
- I have our primary/production SSID on VLAN1 with RADIUS authentication managed through Windows group policy.  The domain controller is the RADIUS server.  Encryption is WPA2.
- When I place a laptop in the correct Active Directory Organizational Unit, the wireless policies are applied to that machine and the host automatically associates with the SSID using either computer authentication or user authentication, defaults to computer authentication.  The security methods are PEAP with EAP-MSCHAPv2.  Works great, has been working well for years.  Images attached for details on the RADIUS configuration.
I need to configure a wireless bridge for use in the lab.  The bridge will provide connectivity to one or two hosts that are not wireless-enabled and cannot be tethered by network cables for a few reasons.  I need the bridge to provide VLAN1 connectivity to the hosts through this RADIUS-authenticated SSID.  I am using the GUI for configuration of the bridge AP, which is an Aironet 1142 with autonomous image version 15.3(3)JAB.
I have created an active directory user account for the AP, which should be all it needs.  I am able to connect a cell phone to this SSID using a valid set of Windows credentials, so I hope the AP can do the same.
I am having difficulty matching up the settings on the AP with my existing wireless configuration. I can't seem to get the bridge to associate, and I'm not sure where to look for detailed debugging.  I have a console session with the bridge, but I'm not super proficient with the CLI.
Rather than go overboard posting lots of information, please tell me what you need to see beyond what I've put in this first post, and I will provide is as quickly as possible.  Hopefully somebody can help me out.
BRIDGE-AP-01#sh run
Building configuration...
Current configuration : 2827 bytes
! Last configuration change at 03:11:05 UTC Fri Mar 1 2002
version 15.3
no service pad
service password-encryption
hostname BRIDGE-AP-01
logging rate-limit console 9
enable secret 5 $1$/EFC$mbtwzj9IBER5APZ8TyvBu1
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
no ip source-route
no ip cef
ip domain name XXXXX.local
ip name-server 192.168.65.4
dot11 syslog
dot11 ssid X_PROD_SSID_X
   vlan 1
   authentication open eap eap_methods
   authentication shared eap eap_methods
   authentication network-eap eap_methods
   dot1x credentials wireless-ap
   dot1x eap profile X_EAP_PROFILE_X
 method peap
 method mschapv2
 username wireless-ap
 password 7 000000000000000000000000
username CISCO password 7 096F471A1A0A
bridge irb
interface Dot11Radio0
 no ip address
 encryption vlan 1 mode ciphers aes-ccm
 broadcast-key vlan 1 change 1024 membership-termination capability-change
 ssid X_PROD_SSID_X
 antenna gain 0
 mbssid
 station-role root
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 antenna gain 0
 peakdetect
 station-role workgroup-bridge
interface Dot11Radio1.1
 bridge-group 1
interface GigabitEthernet0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0.1
 bridge-group 1
interface BVI1
 mac-address 5475.d0b5.4e52
 ip address dhcp
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius server RADIUS_SERVER_HOST_NAME
 address ipv4 192.168.65.8 auth-port 1645 acct-port 1646
 key 7 0000000000000000000000
bridge 1 route ip
line con 0
line vty 0 4
 transport input all
end
BRIDGE-AP-01#
Rasika Nayanajith
If client need to validate RADIUS server certificate, you may have to install server root cert  on your AP.
Also I would go without any sub-interfaces for simplicity. Follow this post for more guidance
https://mrncciew.com/2018/05/25/wgb-with-peap/
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
Looks like either your reply or my original post was marked as SPAM. Not sure why. You post was helpful, I got farther but I'm still not connecting. Having an issue with association or EAP. Hopefully they revive the post so we can continue.
Hi Rasika.  I eventually discovered that because my infrastructure SSID has a space in it, some of the configuration steps would reject my commands.  Perhaps I did not need to match the trustpoint name to the SSID, but I was trying to match your method as closely as possible.
Rather than rename the production SSID, I created a new SSID on a new VLAN, placed the desired root AP into its own AP group on the controller, and configured basic WPA2 security.  With this configuration the bridge works perfectly, and the bridge SSID is limited to only the area where it is required rather than across the entire campus.
Thank you for your help, I believe your information was correct, it was my environment that prevented this from working as expected.
Hi Justin,
Glad to hear that.
Rasika
