Autonoumous AP weak signal
shanilkumar2003
Hi Team,
I have configured an autonomous AP with only default vlan1.  ssid is named guest and its broadcasted. Ap is powered from 1 2960 PoE switch.
I am facing all the sites with below config very weak signal from the AP, kindly help to figure out what could be the issue?
below is the config i applied.
hostname test
dot11 ssid guest
   vlan 1
   authentication open
   authentication key-management wpa
   wpa-psk ascii xxxx
   guest-mode
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 1 mode ciphers tkip
 ssid guest
 station-role root
 no shutdown
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no shutdown
interface GigabitEthernet0.1
 no ip route-cache
 bridge-group 1
 Thanks in Advance..
Shanil
Leo Laohoo
I wouldn't use TKIP.
So the problem only affects 802.11b radio?  What about 802.1a?
