Basic CLI configuration for Aironet 702i access point
Clay Plaga
Level 5
Level 5
Can someone assist me with basic CLI configuration for the Aironet 702i access points. What is the default username and password for logging in to the Aironet 702i access point? After I have logged in to the access point with the console cable, what is the basic configuration that needs to be done on the access point so the AP can connect to a Cisco 2504 WCS that is configured for flex connect? The controller is a our main office, and the AP is at a remote branch office.
Thank You.
Rasika Nayanajith
Cisco/Cisco should work.
You need to simply point your AP to WLC. There are multiple way of doing it without touching AP console. Eg DHCP option 43 and DNS are two method. See below docs for more detail.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/97066-dhcp-option-43-00.html
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/70333-lap-registration.html
If you prefer to static method via CLI, you can use below command via AP console
capwap ap primary-base <WLC_Name> <WLC_Mgt_IP>
See below for more details
http://mrncciew.com/2013/03/17/ap-registration/
Rasika
*** Pls rate all useful responses ***
mohanak
Default Username and Password Are Cisco
When you open the access point interface, you must enter a username and a password. The default username for administrator login is Cisco, and the default password is Cisco. Both the username and password are case sensitive.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/700/quick/guide/ap700getstart.html
http://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/15_2_4_JB/configuration/guide/scg15_2_4_JB3a.pdf
