Basic configuration for a WLAN Controller - 4400
jeremyault
Level 3
Level 3
I've been reading over the "Cisco Wireless LAN Controller Configuration Guide, Release 4.0".
So it looks like once you have the HTTPS enabled and the management IP set, the majority of the configuration is through the GUI - clicking your way through all the settings.
I've never used a wireless LAN controller -- so to make this quick and easy, is it possible to make a "quick and dirty cut and paste" CLI template to get it up and running with just minimal settings left to be done?
If so, could you post it? Thanks.
Scott Fella
Well, first you will have to console into the wlc and go through the startup wizard. that is your minimum configuration to get it working. No way around this unless you build a script to automatically enter information on the startup wizard.
-Scott
