BBSM and RADIUS Authenticated Session Limits
gary.sherry
Community Member
I have setup a BBSM System with RADIUS authentication, the authentication traffic is passed to a seperate RSA Box to authenticate user using fobs and everything works fine.
My question is how do I limited the time a user can have a onnection to the BBSM without having to re-authentication
jreekers
Level 8
Level 8
If you are using the 'Access Code' pageset, when the 'Stop Date and Time' of the Access
Code is reached, all currently connected users who have used that Access Code, are
disconnected.
When you define an Access Code, you define a 'Start Date and Time' and a 'Stop Date and
Time' for the Access Code. All users who have Connected by using that Access Code will be disconnected when that Date/Time is reached.
Please refer to
http://www.cisco.com/en/US/products/sw/netmgtsw/ps533/products_user_guide_ch
apter09186a0080192294.html#1038530
for more information on Access Codes.
HTH,
-Joe
Not using access codes, system is configured to authenticate to an RSA System using Radius; we are using phobs and static password on the RSA box and I wonder if we can get the BBSM to issue a re-authentication request.
Hi Gary.
Sorry...I don't believe that's possible.
-Joe
