BBSM - Basic design for Wireless
Bill CARTER
Level 6
Level 6
I am designing a wireless/BBSM network for a customer. The will have AP's available with both a guest SSID and an Employee SSID. They have non-cisco switches. Can I still use BBSM for guest wireless access?
stschmidt
Level 6
Level 6
As long as the BBSM has IP/SNMP connectivity to the Aironet APs you should not have a problem. I would recommend you use the AP settings with packet inactivity timer in network elements.
stschmidt
Level 6
Level 6
