Best Cisco 4 port wireless device form home with embedded 4g card
I would like to  know a goodt Cisco 4 port wireless device form home with embedded 4g card not too expensive
pedroperez47267
I think the cisco 880G   and 890G are good options as   they both have 4 G support
Leo Laohoo
I would not recommend getting a router with integrated AP.  Why?  Because when the AP is no longer supported by the WLC, then you're in a bind.
Cisco 900-series router is a good choice (Data Sheet) and still runs on "classic" IOS.
Other than that, the CIsco 1000-series is the "premier" line and runs on IOS-XE.
