Best practice for Wireless ap vlan
chrisblake23
Is there a best practice for grouping lightweight access points in one vlan or allowing them to be spread across several ??
Leo Laohoo
Whether you have multiple sites or not, it's good practice to put your APs in a separate and dedicated VLAN.
If your sites are routed sites, then you can re-use the same VLAN numbers but make sure they are on separate subnets and/or VRF instance.
Leo Laohoo
