Best Practise for WLC IDS Signature Thresholds
Rene S.
Hi, are there any best practices for WLC IDS Signature thresholds?
Thanks!
KR,
Rena
mohanak
You can configure IDS signatures, or bit-pattern matching rules used to identify various types of attacks in incoming 802.11 packets, on the controller. When the signatures are enabled, the access points joined to the controller perform signature analysis on the received 802.11 data or management frames and report any discrepancies to the controller. If an attack is detected, appropriate mitigation is initiated.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-5/config_guide/b_cg75/b_cg75_chapter_0111110.html#d162818e187a1635
Thanks for the answer. What I need are best practice thresholds for those signatures, because the default thresholds seem to be very sensitive.
Saurav Lodh
Level 7
Level 7
On aggressive environments, a helpful feature is to enable access point authentication with a threshold of 2. This permits both to detect possible impersonation and minimize false positive detections.
This is how to configure:
config wps ap-authentication enable
config wps ap-authentication threshold 2
