Block device
techbjs08
Visitor
Is their a way to block a device from accessing one SSID and allowing access to another SSID? This is a controller base wireless network. I would like to allow access of a certain device to the corporate network and deny access to the public network. I want to keep both SSID's on all access points.
Thanks in advance!
Ric Beeching
Level 11
Level 11
https://supportforums.cisco.com/discussion/11451031/block-single-client-mac-address-one-ssid-wlc
Please rate helpful / correct posts
Thanks Ric! I will look into this.
gohussai
Level 8
Level 8
Yes it is Possible using "Mac Filtering on controller".
For step by step configuration check the link.
https://www.cisco.com/assets/sol/sb/isa500_emulator/help/guide/ae1244606.html#Rae75180
Do mark as correct if it help 😉
