08-21-2019 04:20 AM - edited 07-05-2021 10:53 AM
Hi all,
I managed to block specific machines from connecting to my ssid by blocking their mac addresses on my 3504 WLC via "security->AAA->Disabld CLients->Manual Disable"
I also manage to verify the logs via CLI using "client debug mac-address" with the logs seen below.
Processing assoc-req station:bb:bb:bb:bb:bb:bb AP:aa:aa:aa:aa:aa:aa-00 ssid : Temp-BYOD thread:1e0eea80
Aug 20 19:12:27.580: [PA] bb:bb:bb:bb:bb:bb Ignoring assoc request due to mobile in exclusion list
Can i also verify the block via GUI other than CLI? TIA!
08-21-2019 05:17 AM
To see the logs, you can go to:
Management>Logs>Message Logs
But need to set the syslog level to debugging: I won't recommended this as it might cause high CPU and you can't trace back that far, rather have the logs be sent to a syslog server.
Management>Logs>Config>Buffered Log Level - Debugging
Sending to a syslog server:
Management>Logs>Config>Syslog server - IP
Syslog level - debugging
***Please mark as an acceptable solution if it answers your question***
08-21-2019 06:40 AM
