Blocking Mobile / IPAD connection to AP
vishal.rane
Hello Guys
I have 4 Cisco Access points registered on WLC 5508. we like to see the option of blocking all Mobile / ipad connection to these Access Points. Allow only Laptops to connect to AP. Appreciate input.
thanks
Vishal
George Stefanick
Vishal
It's rather difficult to do this natively. Cisco ise is the product of choice to handle this type of identity access.
Scott Fella
You can also authenticate using 802.1x and perform machine authentication. Your laptops have to be on the domain and all you need is a radius server. This will prevent non domain devices to authenticate to your wireless.
-Scott
