Blocking Specific MAC from connecting to a specific SSID
mohammad2
WLC Model: Cisco 5520
SW Ver: 8.2.161.0
We have multiple SSIDs configured and each is mapped to a certain VLAN on the network.
I'd like to block certain MAC from connecting to a particular SSID on the WLC.
Using MAC filter doesn't help as it allows list based.
Using disabled clients Blocks Client MAC globally and blocks the MAC from connecting to any SSID which is not desired.
 i need to just block the particular MAC only for one SSID...
so how to do that on WLC
5 Replies 5
Francesco Molino
Do you have a radius server?
Using only wlc, you can achieve this but the other way around, meaning you'll create a list mac filter on wlc and only these mac can connect to the ssid. Mac addresses not present in this list won't be able to connect. Take a look here:
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/91901-mac-filters-wlcs-config.html
If you have a radius, you can create a group with denied mac and tell radius to deny connection for this specific group whereas all others can hit the default rule allowing access.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Dear Franceso,
Thanks for your reply...
"Using only wlc, you can achieve this but the other way around, meaning you'll create a list mac filter on wlc and only these mac can connect to the ssid. Mac addresses not present in this list won't be able to connect."
MAC Filtering Lists i know, we already have a SSID with MAC Filtering enabled and i know how it work, thats not what i want.
For Eg:i have 3 SSID,
1.SALES 2.HR 3.PROJECT
i want to just block a Client MAC in SSID "SALES" but he should be able to connect to other SSID "HR" and "PROJECT"
is it possible..??
Maybe I've not been too clear in my previous answer.
To summarize, it's not possible (nothing I'm aware of) to block a single mac address for 1 ssid.
That's why I've explained the embedded feature on wlc is just to specify which mac addresses you want to allow.
What i suggested is to use a radius server to help you achieve what you want to do.
Francesco
Thankyou,
can you brief how is it can be done in radius server
With a radius server, let's take ise as example:
- create a mab group with the specific mac you want to deny
- create a rule saying:
> If normalised radius ssid contains SALES and identity group equals MABDENY then push authorization profile Deny
Francesco
