Boot loop in U-mode AIR-AP2802-E-S-K9
I got problem with my AP, here is the log please help me.
BootROM - 1.78
Booting from SPI flash, Secure mode
BootROM: RSA Public key verification PASSED
BootROM: CSK block signature verification PASSED
BootROM: Boot header signature verification PASSED
BootROM: Box ID verification PASSED
BootROM: JTAG is disabled
General initialization - Version: 1.0.0
Detected Device ID 6920
Master bootloder version 1.44
High speed PHY - Version: 2.0
BoardId = 0x21board SerDes lanes topology details:
| Lane # | Speed| Type |
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
:** Link is Gen1, check the EP capability
PCIe, Idx 1: Link upgraded to Gen2 based on client cpabilities
PCIe, Idx 2: Link upgraded to Gen2 based on client cpabilities
High speed PHY - Ended Successfully
DDR4 Training Sequence - Ver TIP-0.23.(Sublib 0.8)0
DDR4 Training Sequence - Switching XBAR Window to FastPath Window
DDR4 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
BootROM: Boot image signature verification PASSED
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** LOADER **
U-Boot 2013.01-g2ee3a18aa (Jun 03 2022 - 11:27:17) SDK version: 2015_T2.0p10
Board: Barbados-2K
SoC: MV88F6920 Rev A1
running 2 CPUs
CPU: ARM Cortex A9 MPCore (Rev 1) LE
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DDR4 32 Bit Width,FastPath Memory Access, DLB Enabled, ECC Disabled
DRAM: 1 GiB
RST I2C0
NAND: ECC 4bits, 256 MiB
SF: Detected S25FL032P with page size 64 KiB, total 4 MiB
PCI-e 1 (IF 0 - bus 0) Root Complex Interface, Detected Link X1, GEN 2.0
PCI-e 2 (IF 1 - bus 1) Root Complex Interface, Detected Link X1, GEN 2.0
Map: Code: 0x3fed8000:0x3ffae448
BSS: 0x3ffeff0c
Stack: 0x3f9c7f20
Heap: 0x3f9c8000:0x3fed8000
U-Boot Environment: 0x00100000:0x00110000 (SPI)
Board configuration:
| port | Interface | PHY address |
| egiga1 | SGMII | 0x01 |
| egiga2 | SGMII | 0x00 |
Net: , egiga1, egiga2 [PRIME]
Hit ESC key to stop autoboot: 0
Creating 1 MTD partitions on "nand0":
0x000000200000-0x000010000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBIFS: recovery needed
UBIFS: recovery deferred
UBIFS: mounted UBI device 0, volume 1, name "part2"
Loading file 'part2/part.bin' to addr 0x02000000 with size 6395701 (0x00619735)...
Done
Checking image signing.
Image signing verification success, continue to run...
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Barbados Firmware Image
Created: 2022-12-11 12:29:07 UTC
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 6394693 Bytes = 6.1 MiB
Load Address: 00008000
Entry Point: 00008000
Contents:
Image 0: 4202856 Bytes = 4 MiB
Image 1: 2175684 Bytes = 2.1 MiB
Image 2: 16137 Bytes = 15.8 KiB
Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 02000000 ...
## Flattened Device Tree from multi component Image at 02000000
Booting using the fdt at 0x0261547c
Loading Multi-File Image ... OK
OK
reserving fdt memory region: addr=0 size=4000
Loading Device Tree to 01ff9000, end 01ffff08 ... OK
Starting Device Tree update ('fdt_skip_update' = no)
Limit DDR size at 3GB due to power of 2 requirement of Address decoding
Updating device tree successful
Starting kernel ...
[01/01/1970 00:00:00.0000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
[01/01/1970 00:00:00.0000] Memory: 1025748K/1048576K available (5743K kernel code, 411K rwdata, 2476K rodata, 359K init, 496K bss, 22828K reserved, 0K highmem)
[01/01/1970 00:00:00.1200] CPU1: Booted secondary processor
[01/01/1970 00:00:01.4600] buginf tty flushing thread started, ttyport=be93b000
[01/01/1970 00:00:01.5800] m25p80 spi1.0: found s25sl032p, expected n25q032
[*07/23/2002 11:25:49.5009] buginf() enabled.
[*07/23/2002 11:25:49.5105] Made it into bootsh: Dec 11 2022 12:22:05 T-b2b6a48bc2dd6b13d79591cc3ba0070c803c630f-gb2b6a48b-aut
[*07/23/2002 11:25:57.7570] bootsh mini ramfs booted /bootpart/part2/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
[*07/23/2002 11:26:19.6506] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*07/23/2002 11:26:19.6537] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*07/23/2002 11:26:19.7201] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*07/23/2002 11:26:19.7232] /init: ioctl(SIOCGIFHWADDR): wired0: No such device
[ OK ] Reached target Timers.
[ OK ] Reached target Cisco File Systems (Pre).
[ OK ] Created slice -.slice.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on Delayed Shutdown Socket.
[ OK ] Reached target Sockets.
[ OK ] Created slice system.slice.
[ OK ] Created slice system-sshd\x2dkeygen.slice.
Starting udev Kernel Device Manager...
Starting udev Coldplug all Devices...
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting Cisco UBIFS reformat/mount...
[ OK ] Reached target Slices.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Cisco UBIFS reformat/mount.
Starting Cisco early mount...
[ OK ] Started Cisco early mount.
[ OK ] Reached target Local File Systems (Pre).
Starting Cisco platform file generation...
Starting Cisco system time setup...
Starting Cisco seed generation...
Starting Cisco fips check...
[ OK ] Started Cisco system time setup.
[ OK ] Started Cisco seed generation.
[ OK ] Started Cisco fips check.
[ OK ] Started Cisco platform file generation.
Starting Cisco btldr service...
[*06/25/2019 23:59:59.1017] Last reload time: Apr 18 06:58:32 2023
[*04/18/2023 06:58:32.0076] Setting system time Tue Apr 18 06:58:32 UTC 2023
[*04/18/2023 06:58:33.3003] GCM-128 POST passed
[*04/18/2023 06:58:33.3003] GCM-256 POST passed
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Cisco btldr service.
[ OK ] Reached target Local File Systems.
Starting Cisco S10 boot service...
[04/18/2023 06:58:35.0300] audit: audit_lost=1 audit_rate_limit=0 audit_backlog_limit=64
Starting Securit[04/18/2023 06:58:35.0300] audit: printk limit exceeded
y Auditing Service...
[*04/18/2023 06:58:35.2510] parameter passed without an option given
[*04/18/2023 06:58:35.2536] 29
Starting Cisco act2 check...
[*04/18/2023 06:58:35.4431] Active version: 8.10.183.0
[*04/18/2023 06:58:35.4464] Back Starting Cisco pkg install service...
[ OK ] Started Cisco system time saving.
Starting Cisco system time saving...
[ OK ] Started Security Auditing Service.
[04/18/2023 06:58:36.0200] PCI: enabling device 0000:00:02.0 (0140 -> 0143)
[04/18/2023 06:58:36.1100] PCI: enabling device 0000:02:00.0 (0140 -> 0142)
[ OK ] Started Cisco pkg install service.
[04/18/2023 06:58:42.3900] PCI: enabling device 0000:00:03.0 (0140 -> 0143)
[04/18/2023 06:58:42.4800] PCI: enabling device 0000:03:00.0 (0140 -> 0142)
[ OK ] Stopped target Timers.
[*04/18/2023 06:58:35.7981] device wired0 entered promiscuous mode
[*04/18/2023 06:58:36.1909] wifi0:[ OK ] Removed slice system-serial\x2dgetty.slice.
[ OK ] Removed slice system-sshd\x2dkeygen.slice.
[ OK ] Stopped target Slices.
Stopping Cisco system time saving...
<30>systemd[1]: Stopped target Timers.
[*04/18/2023 06:58:45.9543]
[*04/18/2023 06:58:45.9543] Writing reload timestamp (Tue Apr 18 06:58:45 UTC 2023) to disk
[*04/18/2023 06:58:46.1480] 0; Stoppin[04/18/2023 06:58:46.2400] audit_printk_skb: 36 callbacks suppressed
g Security Auditing Service...
<30>systemd[1]: Stopping Security Auditing Service...
[ OK ] Stopped Cisco pkg install service.
Stopping Cisco pkg install service...
[ OK ] Stopped target Sockets.
[ OK ] Stopped Security Auditing Service.
[ OK ] Stopped Cisco act2 check.
[ OK ] Stopped Cisco system time saving.
[*04/18/2023 06:58:46.7361] 0;[ OK ] Stopped Cisco S10 boot service.
[ OK ] Stopped target Local File Systems.
[ OK ] Stopped Cisco fips check.
Stopping Cisco fips check...
Stopping Cisco seed generation...
Unmounting /firmware...
<30>systemd[1]: Stopped Cisco system time saving.
[*04/18/2023 06:58:47.2461] 0;
[*04/18/2023 06:5 Unmounting /storage...
[ OK ] Stopped Cisco system time setup.
Stopping Cisco system time setup...
Unmounting /tmp...
Unmounting /sys/kernel/debug...
[ OK ] Stopped Cisco btldr service.
Stopping Cisco btldr service...
[ OK ] Stopped Cisco platform file generation.
Stopping Cisco platform file generation...
[ OK ] Stopped Cisco seed generation.
[ OK ] Unmounted /firmware.
[ OK ] Unmounted /storage.
[ OK ] Unmounted /tmp.
[ OK ] Unmounted /sys/kernel/debug.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Cisco early mount.
Stopping Cisco early mount...
[ OK ] Stopped Cisco UBIFS reformat/mount.
Stopping Cisco UBIFS reformat/mount...
[ OK ] Stopped target Cisco File Systems (Pre).
[ OK ] Removed slice system.slice.
[ OK ] Reached target Shutdown.
[ OK ] Reached target Final Step.
Starting Reboot...
[04/18/2023 06:58:50.2500] reboot: Restarting system
BootROM - 1.78
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
marce1000
       >...          >...init: ioctl(SIOCGIFHWADDR): wired0: No such device
 -  This could be  a hardware problem, factory reset , if you still see the same RMA the AP ,
 M.
I tried to reset factory many times but cannot, so what can i do for next step ?
         -  RMA the AP
 M.
