BR350 Association problems
smildren
Community Member
I am bench testing 2 BR350 bridges to be used in a customer's production network. I have one set for Root and the other set for Non-root without clients.
The channel and SSID match. Initially the bridges connect and communicate without a problem. When I remove power from one or both and then repower, they never establish the association. Is this a timeout issue, bad bridge device? Any help appreciated. I do not want a customer call everytime their power blips!!!
ciscomoderator
Administrator
Administrator
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
blue.modal
Level 6
Level 6
How are you re-establishing the connection following a power failure?
So far, I have had to disable spanning tree on the bridges. This allows them to reassociate but drops them back to AP/Root and Site Survey client. I then have to re-enable spanning tree. I was under the impression that the re-association was "automatic".
t-gawronski
Community Member
Spanning Tree is on by default. You can not shut it off without changing the roles of the radios. Leave Spanning Tree on. When you say not associated, is it not showing up on the associations table or is it showing up unassigned? If it is showing up unassigned, this will not change until traffic is passing through it.
