BR500E CRC and transmit packet errors
kadirkocaer
Hi,we 're using br500e (aeronet340) with dish antennas.there is a 2 km between bridges.I think signal levels are ok (60 dbm "in"- 66 dbm "out").But we're having problem with lost packets.we send 2400 packets from router that behind the slave bridge but 2384 packets arrives.Master bridge is shows me CRC and transmit errors.we had try to different frequencies,what can i do to solve this problem.
Best regards.
Beyazit
System support specialist
Noya ltd.co.
smalkeric
Level 11
Level 11
There is a feature called 'Block External to External Transfer' in Call Manager. It comes under the Service Paramaters. I know that is feature is available in version 4.0(1)SR2a, so it should be availabe in 4.0(2) too.
