bridge and AP
aksher
Level 7
Level 7
Does an AP always require a bridge to switch data to other systems in LAN?
7 Replies 7
Richard Atkin
Level 10
Level 10
Yes, Access Points basically just bridge traffic between wired and wireless interfaces, which is achived through the implementation of Bridge-Groups; basically one per VLAN / sub-interface / SSID.
BVI 1 is typically reserved for AP management, and doesn't normally bridge to a Wireless interface.
Want i want to know is the difference between and AP and bridge and their function.
An Access Point is used to allow client devices (laptops, etc..) to connect to a LAN, the SSID they connect to maps to a VLAN via the AP.
A bridge is used to provide a connection between two (or more) locations, just like you would use a wire, but without the wire.
Most Cisco devices can perform both roles, although not at the same time.
Is bridge a mandatory here?
Sorry, I don't understand the question / context. Can you explain the situation in more detail?
Pretty simple, can an AP work in the absence of bridge connecting to other locations.
Yes, an AP is an autonomous device and doesn't require a bridge to operate, just power and ethernet.
