Bridge authentication using EAP
kentdaniel
Community Member
Hi all,
I'm trying to connect two buildings using a point-to-point wireless connection. I'm not having any luck getting a non-root BR1310 to connect to a root BR1310 using open authentication with EAP. My non-root bridge keeps throwing up the error: Interface Dot11Radio0, cannot associate: EAP authenticating.
I have the setup currnetly working using LEAP to the Root's RADIUS server. However, I'd really prefer the RADIUS authentcation use my corporate IAS server which doesn't support LEAP.
Any suggestions?
Thanks!
kentdaniel
Community Member
I talked to TAC and found out that the non-root BR1310 supports authentication as a client only using LEAP. So, I'm back to using the built-in RADIUS server instead of my corporate one.
