bridge
rahman001
Level 5
Level 5
Hi everybody,
I am providing a Cisco WLAN solution to a client  but the speed requirement is 1.4Gbps which is a limitation on Cisco outdoor radio AP.
I chose Cisco Aironet 1552e whose max Speed is 300mbps.  Could you please help me with the way forward because I don’t intend to change vendor.
regards
br
sam
Scott Fella
Well you won't find a Cisco bridge that supports 1gbps throughput. There are other vendors that do support 1gbps but that's it. Cisco partnered up with Exalt and has a 160mbps bridge which is the R5005.
-Scott
Hi fella
Which other vendor support 1Gbps please?
Br
sam
