Bridging and WPA
AdmiralKit
I'm trying to set up a wireless bridge between my 1200 series and 1130AG access points using the "A" radio. I'm doing this because I run the "G" radio in AP mode for my wireless clients to access. However, I can't find the commands to set up the 1200 AP to use the WPA key that I have defined within my 1130. How would I set the WPA key on the 1200 when it is in infrastructure client mode so it will authenticate with my 1130?
bcolvin
Level 3
Level 3
Christopher
Setting up a n AP using the CLI is challenging configuring it as a bridge can be terminal. My recommendation is use the GUI to configure the A radio for bridge operation. Then you will see the CLI commands in the Config File. The proceedure is the same as configuring the 1200 for AP mode except the mode will be Root or Non Root and confguring the Encryption will be the same as for the AP mode.
Bill
