BROADCAST TRAFFIC PROBLEM
ioctl9380
Community Member
After installing the new firmware release in Cisco Aironet 1200 Access Point version 12.3(2)JA , we came up with a problem that occurs in broadcast traffic.
The Access point doesnt forward the broadcast packets transmitted by the station. This problem didnt exist in previous version of firmware (12.2-15-JA)
Any suggestion?
jmagnusson
Level 3
Level 3
See post about 1200 - DHCP problem - When I upgraded we had issues with some clients not getting DHCP addresses - I opened a TAC case and they are trying to recreate - Do you have mutltiple VLAN? running WDS?
I suggest you also open a TAC case...
jmagnusson i dont have neither multiple WLan or wds.
The settings of Access Point is the default.(and the same with the previous firmware)
When i use the previous firmware everything works.
Any other suggestion?
