c3850 built-in WLC and TACACS configuration for Lobby Ambassadoor
yong khang NG
Level 5
Level 5
Hi All
I am using C3850 catalyst switch load with IOS XE 3.7 / 15.2 doing switching and  built in wireless controller feature
For device management, Cisco Secure ACS doing the centralize authentication control  and user identity source is from Microsoft Active Directory server.
The switch is prep with TACACS, everything is doing fine (SSH remote access, Wireless LAN controller login),but i having the problem WLC user role Lobby-Admin can't login.
Question:
Over ACS, What shell profile, command set and authorization rules need to be configure?
Over the switch, what need to be configure over ip http aaa authentication and aaa command?
Attached the config file extract from the switch.
topology setup
01. C3850 WITH IOS-XE 3.7
02. Cisco secure ACS 5.8
03. Microsoft Windows Server 2008 R2 standard edition
Noel
0 Replies 0
