ā11-08-2022 12:54 AM
We have recently deployed no of C9115 APs with WLC 9800 , one of the access points was working perfectly then suddenly went down, after connecting it to console I found it contentiously rebooting , i have tried to access the U-boot and assigned ip address but cant connect it the TFTP server , the switch port which the access point connected to it is always down (although its powered by the switch via PoE) , i suspect the gigaethernet port is faulty ,your help is much appreciated.
Console Log:
bELO
5.0205HNDRC1a-1.0.38-163.162
CPU0
L1CD
MMUI
MMUA
CODE
ZBBS
MAIN
Boot Strap Register: 0x6fc3b
NVRAM memcfg 0x41627
DDR3-1600 CL11 total 2048MB 2 16bits part[s] %1 SSC
DDR test done successfully
CFE Version: 5
Verifying MASTER U-Boot...
Launching MASTER U-Boot version 0x0044 ...
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
U-Boot 2017.09 (Feb 05 2021 - 11:50:07 -0800) Broadcom BCM49408
Board: SS-i
I2C: ready
DRAM: 2 GiB
enable MMU ... OK
NAND: Status wait timeout: nandsts=0x0 mask=0x40000000, count=0
NAND ECC BCH-8, page size 4096 bytes, spare size used 216 bytes
1024 MiB
MMC:
SF: Detected mx25l6405d with page size 256 Bytes, erase size 4 KiB, total 8 MiB
In: serial
Out: serial
Err: serial
Platform: 4908
pmc_init:PMC using DQM mode
pmc_patch_4908:7 0 fb7a044e 36a036a
Board IP address : 10.1.1.101:ffffff00
Host IP address : 10.1.1.10
Gateway IP address : 10.1.1.1
Run from flash/host/tftp (f/h/c) : f
Default host run file name : vmlinux
Default host flash file name : bcm963xx_fs_kernel
Boot delay (0-9 seconds) : 3
Default host ramdisk file name :
Default ramdisk store address :
Board Id (0-18) : 949408EAP_54991
Number of MAC Addresses (1-32) : 11
Base MAC Address : c8:84:a1:af:d6:4c
PSI Size (1-128) KBytes : 48
Enable Backup PSI [0|1] : 0
System Log Size (0-256) KBytes : 0
Auxillary File System Size Percent: 0
flow memory allocation (MB) : 43
buffer memory allocation (MB) : 16
DHD 0 memory allocation (MB) : 0
DHD 1 memory allocation (MB) : 0
DHD 2 memory allocation (MB) : 0
Partition 1 Size (MB) : 0M
Partition 2 Size (MB) : 0M
Partition 3 Size (MB) : 0M
Partition 4 Size (MB) (Data) : 4M
BootImage: MASTER
Found external PHY firmware image
MTDPART Str = (mtdparts=nand:1m(nvram),5888k(bootfs),-(fs))
Net: Registering Ethernet Driver.....
Broadcom BCM 4908 Ethernet driver 0.1
pmc_switch_power_up: Rgmii Tx clock zone1 enable 0 zone2 enable 0.
Setting SGMII Calibration value to 0x9
swap_pair = 0
Detecting PHYs...
84880 A0 ae02:5158 --> N/A
84881 A0 ae02:5150 --> N/A
84884 A0 ae02:5148 --> N/A
84884E A0 ae02:5168 --> N/A
84885 A0 ae02:5178 --> N/A
84886 A0 ae02:5170 --> N/A
84887 A0 ae02:5144 --> N/A
84888 A0 ae02:5140 --> N/A
84888E A0 ae02:5160 --> N/A
84888S A0 ae02:5174 --> N/A
84880 B0 ae02:5159 --> N/A
84881 B0 ae02:5151 --> N/A
84884 B0 ae02:5149 --> N/A
84884E B0 ae02:5169 --> N/A
84885 B0 ae02:5179 --> N/A
84886 B0 ae02:5171 --> N/A
84887 B0 ae02:5145 --> N/A
84888 B0 ae02:5141 --> N/A
84888E B0 ae02:5161 --> N/A
84888S B0 ae02:5175 --> N/A
84891 A0 3590:5090 --> N/A
54991 A0 3590:5094 --> N/A
54991E A0 3590:5098 --> N/A
84891L A0 3590:5080 --> N/A
54991L A0 3590:5084 --> N/A
54991EL A0 3590:5088 --> N/A
84892 A0 3590:50a0 --> N/A
54992 A0 3590:50a4 --> N/A
54992E A0 3590:50a8 --> N/A
84894 A0 3590:50b0 --> N/A
54994 A0 3590:50b4 --> N/A
54994E A0 3590:50b8 --> N/A
54991H A0 3590:50d0 --> N/A
54994H A0 3590:50f0 --> N/A
84891 B0 3590:5091 --> N/A
54991 B0 3590:5095 --> N/A
54991E B0 3590:5099 --> N/A
84891L B0 3590:5081 --> N/A
54991L B0 3590:5085 --> N/A
54991EL B0 3590:5089 --> 0x1f
84892 B0 3590:50a1 --> N/A
54992 B0 3590:50a5 --> N/A
54992E B0 3590:50a9 --> N/A
84894 B0 3590:50b1 --> N/A
54994 B0 3590:50b5 --> N/A
54994E B0 3590:50b9 --> N/A
54991H B0 3590:50d1 --> N/A
54994H B0 3590:50f1 --> N/A
Loading firmware into detected phys...
Firmware version: Blackfin B0 v02-02-03-2020-03-16
Loading firmware into phys: map=0x80000000
Halt the phys processors operation
Upload the firmware into the on-chip memory
100%
Reset the processors to start execution of the code in the on-chip memory
Verify that the processors are running: Failed
bcm4908_eth-0
MAC: c8:84:a1:af:d6:4c
Hit ESC key to stop autoboot: 0
Mounting UBI device fs
ubi0: attaching mtd3
ubi0: scanning is finished
ubi0: attached mtd3 (name "mtd=2", size 1017 MiB)
ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
ubi0: good PEBs: 4069, bad PEBs: 0, corrupted PEBs: 0
ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 32/15, WL threshold: 4096, image sequence number: 1636155361
ubi0: available PEBs: 33, total reserved PEBs: 4036, PEBs reserved for bad PEB handling: 80
Load Addr 0x10000000
Mount UBIFS PARTITION part2 ...
Loading file 'part2/part.bin' to addr 0x10000000...
Done
Checking image signing.
Image signing verification success for part part2 continue to run...
Multi Image Header Found
Count = 0 Offset = 0x10000050 Len = 10985760
Count = 1 Offset = 0x10a7a170 Len = 3065172
Count = 2 Offset = 0x10d666c4 Len = 7202
Booting from Partition: part2
arg 0: 0x10000050
arg 1: 0x3000000
arg 2: 0x1800000
## Loading init Ramdisk from Legacy Image at 03000000 ...
Image Name: Simple Ramdisk Image
Created: 2021-03-03 8:29:59 UTC
Image Type: AArch64 Linux RAMDisk Image (lzma compressed)
Data Size: 3065108 Bytes = 2.9 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 01800000
Booting using the fdt blob at 0x1800000
load dtb from fixed memory location directly...
/memory = 0x80000000 bytes @ 0x0
Set Memory to 2147483648l
WARNING: Node's property /reserved-memory/dt_reserved_buffer is not defined
WARNING: Node's property /reserved-memory/dt_reserved_flow is not defined
Appending NVRAM to dtb, ret:0
Loaded DTB from 0x01800000 with size 7202l
Curr Boot Args: <NULL>
DTB Boot Args (coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait crashkernel=128M@0M)
Bootargs set to setenv bootargs console=$consoledev,$baudrate activepart=part2 activeboot=0 bootver=0x44 boardid=0x0 forceboot=0 coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait crashkernel=128M@0M $console $nandEcc $mtdparts ubi.mtd=fs BOOT_DEBUG=0
Cleanup Complete.... ARMv8_secure_init_done!!!
Loading Ramdisk to 4fbba000, end 4fea6514 ... OK
reserving fdt memory region: addr=0 size=20000
Using Device Tree in place at 0000000001800000, end 0000000001804c21
Starting kernel ...
[01/01/1970 00:00:02.6980] hub 3-0:1.0: config failed, hub doesn't have any ports! (err -19)
[01/01/1970 00:00:02.7900] brcmboard registered
[*01/01/1970 00:00:14.1520] buginf() enabled.
[*01/01/1970 00:00:14.1580] Made it into bootsh: Mar 3 2021 08:06:36 T-0b7bc0faa97ae8a26ea605c7622aac357397184c-g0b7bc0fa-aut
[*01/01/1970 00:00:22.5510] bootsh mini ramfs booted /bootpart/part2/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
[*01/01/1970 00:00:45.8580] init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:45.8600] init: ioctl(SIOCGIFHWADDR): wired0: No such device
Press S for a shell, or another magic key...
[ OK ] Reached target Timers.
[ OK ] Created slice -.slice.
&j OK ] Listening on Delayed Shutdown Socket.
iM)&j
i5) Starting Cisco UBIFS reformat/mount...
[*01/01/1970 00:00:50.1720] root: Cisco Axel file system mounting
[ OK ] Reached target Slices.
&j OK ] Created slice system-serial\x2dgetty.slice.
i
Ķ32m OK ] Started Cisco UBIFS reformat/mount.
Starting Cisco early mount...
[ OK ] Started Cisco early mount.
[ OK ] Reached target Local File Systems (Pre).
Starting Cisco platform file generation...
Starting Cisco seed generation...
Starting Cisco system time setup...
[*04/23/2021 23:59:59.0090] Last reload time: Oct 31 15:13:28 2022
[*10/31/2022 15:13:28.0000] Setting system time Mon Oct 31 15:13:28 UTC 2022
Starting Cisco fips check...
[ OK ] Started Cisco platform file generation.
[*10/31/2022 15:13:28.2390] GCM-128 POST passed
[*10/31/2022 15:13:28.2390] GCM-256 POST passed
[ OK ] Started Cisco seed generation.
ڵMŃ
Starting Cisco btldr service....
[*10/31/2022 15:13:28.5560]
[*10/31/2022 15:13:28.5560] [10/31/2022 15:14:29] : Shadow is now in-synced with master
[ OK ] Started Cisco btldr service.
[ OK ] Reached target Local File Systems.
Starting Cisco pkg install service...
Starting Cisco S10 boot service...
[ OK ] Started Cisco system time saving.
[*10/31/2022 15:13:28.9400] 12 ل31/2022 15:13:29.0120] Active version: 17.3.3.26
[*10/31/2022 15:13:29.0140] Backup version: 16.12.4.31
[[10/31/2022 15:13:29.1580] bcmlibs: module license 'Proprietary' taints kernel.
[10/31/2022 15:13:29.2440] Disabling lock debugging due to kernel taint
*10/31/2022 15:13:29.1460] Loading BCM modules ...
[*10/31/2022 15:13:29.1460] Ignore pptp.ko
[*10/31/2022 15:13:29.1480] Ignore pktflow.ko
[*10/31/2022 15:13:29.1500] Ignore pktrunner.ko
[*10/31/2022 15:13:29.1520] Load bcmlibs.ko
[*10/31/2022 15:13:29.3210] BCMLIBS loaded...
[*[10/31/2022 15:13:29.6200] bm_base_addr 0xffffffc006000000, size 67108864, bm_base_addr_phys 0x0000000006000000
[10/31/2022 15:13:29.7370] fm_base_addr 0xffffffc002e00000, size 12582912, fm_base_addr_phys 0x0000000002e00000
10/31/2022 15:13:29.3310] Load wlcsm.ko
[*10/31/2022 15:13:29.3520] Load rdp_fpm.ko
[*10/31/2022 15:13:29.3920] Load bdmf.ko
[*10/31/2022 15:13:29.4150] Load proclikefs.ko
[*10/31/2022 15:13:29.4310] Load rdpa_gpl.ko
[*10/31/2022 15:13:29.4480] Load rdpa_gpl_ext.ko
[*10/31/2022 15:13:29.4640] Load rdpa.ko
[*10/31/2022 15:13:29.5260] Load rdpa_usr.ko
[*10/31/2022 15:13:29.5460] Load rdpa_mw.ko
[*10/31/2022 15:13:29.8550] RDP Physical address=0x82200000 Virtual address = 0xffffff8001c80000
[*10/31/2022 15:13:29.8680] configure_runner: NATC keysize 0x100070 key element size 16 contextsize 0x400000 context element size 64
[*10/31/2022 15:13:29.8680] ++++Runner [10/31/2022 15:13:30.5610] Broadcom Command List Driver v1.0
gso_desc_pool created succ[10/31/2022 15:13:30.6460] crossbar[0]: Allocated cb_idx=0 int_ep=0
[10/31/2022 15:13:30.7240] crossbar[0]: Add cb_idx=0 ext_ep=0 SERDES:6
[10/31/2022 15:13:30.7990]
[10/31/2022 15:13:30.7990] Detecting PHYs...
[10/31/2022 15:13:30.8770] Lift PHY at address 31 out of Reset by GPIO:31 Active Low
essfully
[*1[10/31/2022 15:13:30.9740] 54991EL B0 3590:5089 --> 0x1f
[10/31/2022 15:13:31.0440]
[10/31/2022 15:13:31.0440] Loading firmware into detected PHYs...
[10/31/2022 15:13:31.1740] Firmware version: Blackfin B0 v02-02-03-2020-03-16
[10/31/2022 15:13:31.2570] Loading firmware into PHYs: map=0x80000000 count=1
[10/31/2022 15:13:31.3390] Halt the PHYs processors operation
[10/31/2022 15:13:31.4070] Upload the firmware into the on-chip memory
2%700000er_nat_cache_key_ptr=0xffffffc003
4%tr=0xffffffc002e00000at_cache_context_p
6%ext_cont_ptr=0xffffffc003200000ner_cont
9%0x82c30000,virt_addr 0xffffff80018f8000
[*10/31/2022 15:13:30.3540]
13%enum <5>; Allocating <15360> bufs; RDP
14%oad chipinfo.ko:30.5120] L
16%entry brcmchipinfo: brcm_chipinfo_init
17% rdpa_cmd.ko:13:30.5300] Load
18%0] Load cmdlist.ko.553
19%30.6350] Load bcm_enet.ko
21%b_idx:0 int_ep 0 to ext_ep 0 connect c
23%ct cb_idx:0 int_ep 1 to ext_ep 2 conne
24% Startin
[10/31/2022 15:13:32.5860] audit_printk_skb: 6 callbacks suppressed
26%/31/2022 15:13:32.6680]
28%/31/2022 15:13:32.7090]
29%/31/2022 15:13:32.7460]
30%/31/2022 15:13:32.7800]
31%/31/2022 15:13:32.8140]
32%/31/2022 15:13:32.8490]
33%/31/2022 15:13:32.8840]
34%/31/2022 15:13:32.9180]
35%/31/2022 15:13:32.9520]
36%/31/2022 15:13:32.9870]
38%diting Service...2022 15:13:32.9950]
40%ion givenarameter passed without an opt
41%g Cisco act2 check...
43%g Service.arted Security Auditin
76%co pkg install service.
100%
[10/31/2022 15:13:35.1360] Reset the processors to start execution of the code in the on-chip memory
[10/31/2022 15:13:35.2410] Verify that the processors are running: Failed
[10/31/2022 15:13:37.3340] Adjusted SF2 SGPHY: sphy_ctrl=0x00010c1b
[10/31/2022 15:13:37.4170] getrcal for res select 5, int 662, ext 644, ratio 124 ratio1 144, rcal 9
[10/31/2022 15:13:37.5150] Setting SGMII Calibration value to 0x9
[10/31/2022 15:13:37.5850] PLL_PON(8051): 0x0250; TX_PON(8067): 0x0048; RX_PON(80b2): 0x0980
[ OK ] Started Cisco act2 check.
[10/31/2022 15:13:39.8670] ------------[ cut here ]------------
[10/31/2022 15:13:39.9280] kernel BUG at /san1/BUILD/workspace/c173_throttle_axel-bcm_17_3_3_26_CCO/base/build_axel-bcm/bcmdrv-build/shared/opensource/drv/phys/phy_drv_sf2_serdes.c:199!
[10/31/2022 15:13:40.1230] Internal error: Oops - BUG: 0 [#1] SMP
[10/31/2022 15:13:40.1930] Modules linked in: act2_driver(O) init_addr( (null) - (null)), core_addr(ffffffbffc412000 - ffffffbffc41255c)
[10/31/2022 15:13:40.3560] bcm_enet(O+) init_addr(ffffffbffc408000 - ffffffbffc408c34), core_addr(ffffffbffc3de000 - ffffffbffc3f737c)
[10/31/2022 15:13:40.4990] cmdlist(PO) init_addr( (null) - (null)), core_addr(ffffffbffc3c2000 - ffffffbffc3cdce4)
[10/31/2022 15:13:40.6410] rdpa_cmd(O) init_addr( (null) - (null)), core_addr(ffffffbffc3a5000 - ffffffbffc3b2a9c)
[10/31/2022 15:13:40.7830] chipinfo(PO) init_addr( (null) - (null)), core_addr(ffffffbffc3a1000 - ffffffbffc3a112c)
[10/31/2022 15:13:40.9260] rdpa_mw(O) init_addr( (null) - (null)), core_addr(ffffffbffc395000 - ffffffbffc3993b0)
[10/31/2022 15:13:41.0670] rdpa_usr(O) init_addr( (null) - (null)), core_addr(ffffffbffc386000 - ffffffbffc38bf60)
[10/31/2022 15:13:41.2090] rdpa(PO) init_addr( (null) - (null)), core_addr(ffffffbffc1b6000 - ffffffbffc227e0c)
[10/31/2022 15:13:41.3470] rdpa_gpl_ext(O) init_addr( (null) - (null)), core_addr(ffffffbffc1b2000 - ffffffbffc1b20a0)
[10/31/2022 15:13:41.4930] rdpa_gpl(O) init_addr( (null) - (null)), core_addr(ffffffbffc199000 - ffffffbffc19a5f8)
[10/31/2022 15:13:41.6350] proclikefs(O) init_addr( (null) - (null)), core_addr(ffffffbffc194000 - ffffffbffc194754)
[10/31/2022 15:13:41.7790] bdmf(O) init_addr( (null) - (null)), core_addr(ffffffbffc04f000 - ffffffbffc069f6c)
[10/31/2022 15:13:41.9170] rdp_fpm(O) init_addr( (null) - (null)), core_addr(ffffffbffc042000 - ffffffbffc0453a0)
[10/31/2022 15:13:42.0580] wlcsm(PO) init_addr( (null) - (null)), core_addr(ffffffbffc03d000 - ffffffbffc03e014)
[10/31/2022 15:13:42.1980] bcmlibs(PO) init_addr( (null) - (null)), core_addr(ffffffbffc037000 - ffffffbffc038124)
[10/31/2022 15:13:42.3390] aptrace(O) init_addr( (null) - (null)), core_addr(ffffffbffc00c000 - ffffffbffc01ee6c)
[10/31/2022 15:13:42.4800] mbedtls(O) init_addr( (null) - (null)), core_addr(ffffffbffc000000 - ffffffbffc003cd8)
[10/31/2022 15:13:42.6210]
[10/31/2022 15:13:42.6510] CPU: 1 PID: 1753 Comm: insmod Tainted: P O 4.1.52 #5
[10/31/2022 15:13:42.7490] Hardware name: Broadcom-v8A (DT)
[10/31/2022 15:13:42.8130] task: ffffffc07cdb5e00 ti: ffffffc07a7b4000 task.ti: ffffffc07a7b4000
[10/31/2022 15:13:42.9150] PC is at dsl_runner_ext3_phy_init+0x298/0x440
[10/31/2022 15:13:42.9930] LR is at dsl_runner_ext3_phy_init+0x164/0x440
[10/31/2022 15:13:43.0700] pc : [<ffffffc0004bfbd8>] lr : [<ffffffc0004bfaa4>] pstate: 60000145
[10/31/2022 15:13:43.1710] sp : ffffffc07a7b7a60
[10/31/2022 15:13:43.2230] x29: ffffffc07a7b7a60 x28: ffffffc0004c2910
[10/31/2022 15:13:43.2990] x27: ffffffc0004c4638 x26: ffffffc0004c5960
[10/31/2022 15:13:43.3750] x25: ffffffc0004c5870 x24: ffffffc00096bb60
[10/31/2022 15:13:43.4520] x23: 0000000000000001 x22: ffffffc000b9f000
[10/31/2022 15:13:43.5280] x21: 0000000000000030 x20: ffffffc000b9d4c8
[10/31/2022 15:13:43.6040] x19: 0000000000000000 x18: ffffffc000b04c28
[10/31/2022 15:13:43.6800] x17: 00000000000007e6 x16: 00000000000001ec
[10/31/2022 15:13:43.7560] x15: ffffffc000b0485c x14: 30203a2932623038
[10/31/2022 15:13:43.8320] x13: 0000000000000000 x12: 0000000000000000
[10/31/2022 15:13:43.9080] x11: 0000000000000003 x10: 00000000000000fd
[10/31/2022 15:13:43.9850] x9 : 0000000000000020 x8 : ffffffc07a7b78d0
[10/31/2022 15:13:44.0590] x7 : ffffffc07ffb3ac0 x6 : ffffffc07a7b78d0
[10/31/2022 15:13:44.0590] x5 : 000000002fe10000 x4 : ffffffc07a7b7afa
[10/31/2022 15:13:44.0590] x3 : ffffffc000afda80 x2 : 000000012272b7fa
[10/31/2022 15:13:44.0590] x1 : 00000000000061a8 x0 : 00000000000061a8
[10/31/2022 15:13:44.0590] Process insmod (pid: 1753, stack limit = 0xffffffc07a7b4020)
[10/31/2022 15:13:44.0590] Stack: (0xffffffc07a7b7a60 to 0xffffffc07a7b8000)
[10/31/2022 15:13:44.0590] 7a60: 7a7b7b00 ffffffc0 004b4f68 ffffffc0 00b9d4c8 ffffffc0 00b9d440 ffffffc0
[10/31/2022 15:13:44.0590] 7a80: 004b3c80 ffffffc0 00000072 00000000 00000003 00000000 00b4a000 ffffffc0
[10/31/2022 15:13:44.0590] 7aa0: 00000002 00000000 00000002 00000000 00000001 00000000 00000002 00000000
[10/31/2022 15:13:44.0590] 7ac0: 004b3c80 ffffffc0 004c5790 ffffffc0 004c2880 ffffffc0 0096b9f8 ffffffc0
[10/31/2022 15:13:44.0590] 7ae0: 0085d3c8 ffffffc0 00000001 0000000a 004b3c80 ffffffc0 80000b8c 35905089
[10/31/2022 15:13:44.0590] 7b00: 7a7b7b30 ffffffc0 fc3e0be4 ffffffbf 00b9cb50 ffffffc0 00000000 00000000
[10/31/2022 15:13:44.0590] 7b20: 00000000 00000000 00000000 00002600 7a7b7b70 ffffffc0 fc3e1010 ffffffbf
[10/31/2022 15:13:44.0590] 7b40: 00000004 00000000 28a69c00 ffffffc0 fc3f9970 ffffffbf fc3e10b4 ffffffbf
[10/31/2022 15:13:44.0590] 7b60: 00000000 00000000 28a68c00 ffffffc0 7a7b7ba0 ffffffc0 fc3e1060 ffffffbf
[10/31/2022 15:13:44.0590] 7b80: 00000000 00000000 28a69000 ffffffc0 fc3f9970 ffffffbf 00000072 00000000
[10/31/2022 15:13:44.0590] 7ba0: 7a7b7bd0 ffffffc0 fc4081b0 ffffffbf fc3fe000 ffffffbf fc3f7000 ffffffbf
[10/31/2022 15:13:44.0590] 7bc0: fc3fe000 ffffffbf 7a7b7c40 ffffffc0 7a7b7c50 ffffffc0 00081834 ffffffc0
[10/31/2022 15:13:44.0590] 7be0: 0091be60 ffffffc0 0091be60 ffffffc0 7971dc40 ffffffc0 fc408000 ffffffbf
[10/31/2022 15:13:44.0590] 7c00: 00000000 00000000 7af6e010 ffffffc0 7af6e000 ffffffc0 01d81000 ffffff80
[10/31/2022 15:13:44.0590] 7c20: 3f242800 ffffffc0 00000124 00000000 7971dc40 00000001 003c0000 ffffff80
[10/31/2022 15:13:44.0590] 7c40: 00000000 00000002 00081824 ffffffc0 7a7b7cd0 ffffffc0 006667c0 ffffffc0
[10/31/2022 15:13:44.0590] 7c60: fc3fe738 ffffffbf 00000000 00000000 7971d0c0 ffffffc0 00000001 00000000
[10/31/2022 15:13:44.0590] 7c80: fc3fe788 ffffffbf 00000001 00000000 fc3fe788 ffffffbf 00000001 00000000
[10/31/2022 15:13:44.0590] 7ca0: 7a7b7cd0 ffffffc0 00666768 ffffffc0 fc3fe738 ffffffbf 00000001 00000000
[10/31/2022 15:13:44.0590] 7cc0: fc3fe738 ffffffbf 00000001 00000000 7a7b7d00 ffffffc0 00105734 ffffffc0
[10/31/2022 15:13:44.0590] 7ce0: 7a7b7e58 ffffffc0 00000001 00000000 fc3fe738 ffffffbf 00000001 00000000
[10/31/2022 15:13:44.0590] 7d00: 7a7b7e00 ffffffc0 00105d60 ffffffc0 00002839 00000000 00000000 00000000
[10/31/2022 15:13:44.0590] 7d20: a7667849 0000007f 01dc3839 ffffff80 3b32bb60 00000000 7a7b4000 ffffffc0
[10/31/2022 15:13:44.0590] 7d40: 00010000 00000000 00000069 00000000 00674000 ffffffc0 7a7b4000 ffffffc0
[10/31/2022 15:13:44.0590] 7d60: 00000077 ffffffc0 00165be4 00000072 00000064 ffffff80 0000006e ffffffbf
[10/31/2022 15:13:44.0590] 7d80: 0000003f ffffffbf 0067e398 ffffffc0 0000feff ffffffc0 7a7b7df8 ffffffc0
[10/31/2022 15:13:44.0590] 7da0: fc3fddd0 ffffffbf a7740001 0000007f 3b32bb60 00000000 00000015 00000000
[10/31/2022 15:13:44.0590] 7dc0: 0000011a 00000000 fc3f73a0 ffffffbf 00000002 00000000 00000000 00000000
[10/31/2022 15:13:44.0590] 7de0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[10/31/2022 15:13:44.0590] 7e00: ec384b10 0000007f 00084db0 ffffffc0 00000000 00000000 a7625010 0000007f
[10/31/2022 15:13:44.0590] 7e20: ffffffff ffffffff a7740384 0000007f 80000000 00000000 00000015 00000000
[10/31/2022 15:13:44.0590] 7e40: 0000011a 00000000 00181d34 ffffffc0 795fe400 ffffffc0 01d81000 ffffff80
[10/31/2022 15:13:44.0590] 7e60: 000425d8 00000000 01da29f8 ffffff80 01da28df ffffff80 01da7cd8 ffffff80
[10/31/2022 15:13:44.0590] 7e80: 00022bd8 00000000 000262e0 00000000 00000000 00000000 00000000 00000001
[10/31/2022 15:13:44.0590] 7ea0: 00008c78 00000000 0000001c 0000001d 00000016 00000000 00000011 00000000
[10/31/2022 15:13:44.0590] 7ec0: a7625010 0000007f 00042839 00000000 3b32bb60 00000000 a7625010 0000007f
[10/31/2022 15:13:44.0590] 7ee0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[10/31/2022 15:13:44.0590] 7f00: 00000069 00000000 ec385e05 0000007f 01010101 01010101 00000008 00000000
[10/31/2022 15:13:44.0590] 7f20: 01010101 01010101 20657669 66667830 66666666 63666662 00000008 00000000
[10/31/2022 15:13:44.0590] 7f40: a7740360 0000007f 00413390 00000000 00000000 00000000 ec385e05 0000007f
[10/31/2022 15:13:44.0590] 7f60: a7625010 0000007f 00000003 00000000 00042839 00000000 3b32bb60 00000000
[10/31/2022 15:13:44.0590] 7f80: ec384e18 0000007f 00402bc5 00000000 00000020 00000000 00000000 00000000
[10/31/2022 15:13:44.0590] 7fa0: 00000000 00000000 ec384b10 0000007f 00402284 00000000 ec384b10 0000007f
[10/31/2022 15:13:44.0590] 7fc0: a7740384 0000007f 80000000 00000000 a7625010 0000007f 00000069 00000000
[10/31/2022 15:13:44.0590] 7fe0: 00000000 00000000 00000000 00000000 a95a67fa a9596ffc 9107c3ff d65f03c0
[10/31/2022 15:13:44.0590] Call trace:
[10/31/2022 15:13:44.0590] [<ffffffc0004bfbd8>] dsl_runner_ext3_phy_init+0x298/0x440
[10/31/2022 15:13:44.0590] [<ffffffc0004b4f68>] cb_init+0x100/0x178
[10/31/2022 15:13:44.0590] [<ffffffbffc3e0be4>] port_init+0x10c/0x4e8 [bcm_enet]
[10/31/2022 15:13:44.0590] [<ffffffbffc3e1010>] sw_init+0x50/0x1b0 [bcm_enet]
[10/31/2022 15:13:44.0590] [<ffffffbffc3e1060>] sw_init+0xa0/0x1b0 [bcm_enet]
[10/31/2022 15:13:44.0590] [<ffffffbffc4081b0>] init_module+0x1b0/0x30c [bcm_enet]
[10/31/2022 15:13:44.0590] [<ffffffc000081834>] do_one_initcall+0x8c/0x1a0
[10/31/2022 15:13:44.0590] [<ffffffc0006667c0>] do_init_module+0x7c/0x1cc
[10/31/2022 15:13:44.0590] [<ffffffc000105734>] load_module+0x1a04/0x1ec0
[10/31/2022 15:13:44.0590] [<ffffffc000105d60>] SyS_init_module+0x170/0x198
[10/31/2022 15:13:44.0590] Code: a9080e64 f9004e62 a90d8660 17ffff74 (d4210000)
[10/31/2022 15:13:44.0590] ---[ end trace 33dadd496072d6bb ]---
[10/31/2022 15:13:44.0590] Kernel panic - not syncing: Fatal exception
[10/31/2022 15:13:44.0590] CPU0: stopping
[10/31/2022 15:13:44.0590] CPU: 0 PID: 0 Comm: swapper/0 Tainted: P D O 4.1.52 #5
[10/31/2022 15:13:44.0590] Hardware name: Broadcom-v8A (DT)
[10/31/2022 15:13:44.0590] [<ffffffc000088d30>] dump_backtrace+0x0/0x150
[10/31/2022 15:13:44.0590] [<ffffffc000088e94>] show_stack+0x14/0x20
[10/31/2022 15:13:44.0590] [<ffffffc000668ad8>] dump_stack+0x90/0xb0
[10/31/2022 15:13:44.0590] [<ffffffc00008fa4c>] handle_IPI+0x1ec/0x200
[10/31/2022 15:13:44.0590] [<ffffffc000081468>] gic_handle_irq+0x88/0x90
[10/31/2022 15:13:44.0590] Exception stack(0xffffffc00090bd80 to 0xffffffc00090beb0)
[10/31/2022 15:13:44.0590] bd80: a22f5330 0000000f 00000000 00000080 0090bed0 ffffffc0 004750d4 ffffffc0
[10/31/2022 15:13:44.0590] bda0: a22f5330 0000000f a0000000 0003906c 00009b98 00000000 14000000 00000000
[10/31/2022 15:13:44.0590] bdc0: 00020a0e 00000000 00000018 00000000 c0000000 00038444 00000400 00000000
[10/31/2022 15:13:44.0590] bde0: 0091c6d0 ffffffc0 0090be70 ffffffc0 00000000 00000000 0000049d 00000000
[10/31/2022 15:13:44.0590] be00: 00000000 00000000 00000000 00000000 00001400 00000000 00001800 00000000
[10/31/2022 15:13:44.0590] be20: 00001000 00000000 00001c00 00000000 00000002 00000000 a22f5330 0000000f
[10/31/2022 15:13:44.0590] be40: 7ffa7b00 ffffffc0 00000001 00000000 00000001 00000000 a2276fa8 0000000f
[10/31/2022 15:13:44.0590] be60: 00677000 ffffffc0 00908000 ffffffc0 00902000 ffffffc0 7ffa7b00 ffffffc0
[10/31/2022 15:13:44.0590] be80: 00968b30 ffffffc0 0090bed0 ffffffc0 004750cc ffffffc0 0090bed0 ffffffc0
[10/31/2022 15:13:44.0590] bea0: 004750d4 ffffffc0 60000145 00000000
[10/31/2022 15:13:44.0590] [<ffffffc000084700>] el1_irq+0x80/0x100
[10/31/2022 15:13:44.0590] [<ffffffc0004751c8>] cpuidle_enter+0x18/0x20
[10/31/2022 15:13:44.0590] [<ffffffc0000d48e8>] cpu_startup_entry+0x1c0/0x218
[10/31/2022 15:13:44.0590] [<ffffffc0006650b4>] rest_init+0x74/0x80
[10/31/2022 15:13:44.0590] [<ffffffc0008c397c>] start_kernel+0x38c/0x3a0
[10/31/2022 15:13:44.0590] CPU2: stopping
[10/31/2022 15:13:44.0590] CPU: 2 PID: 0 Comm: swapper/2 Tainted: P D O 4.1.52 #5
[10/31/2022 15:13:44.0590] Exception stack(0xffffffc07d4d7dc0 to 0xffffffc07d4d7ef0)
[10/31/2022 15:13:44.0590] 7dc0: a22f5330 0000000f 00000000 00000080 7d4d7f10 ffffffc0 004750d4 ffffffc0
[10/31/2022 15:13:44.0590] 7de0: a22f5330 0000000f a0000000 0003906c 00009b98 00000000 14000000 00000000
[10/31/2022 15:13:44.0590] 7e00: 00020a0e 00000000 00000018 00000000 c0000000 00038444 00000400 00000000
[10/31/2022 15:13:44.0590] 7e20: 7d4c9200 ffffffc0 7d4d7eb0 ffffffc0 00000000 00000000 00000003 00000000
[10/31/2022 15:13:44.0590] 7e40: 00000000 00000000 00000000 00000000 0000000e 00000000 00000007 00000000
[10/31/2022 15:13:44.0590] 7e60: 00000001 00000000 00000007 00000000 0000000e 00000000 a22f5330 0000000f
[10/31/2022 15:13:44.0590] 7e80: 7ffc7b00 ffffffc0 00000001 00000000 00000001 00000000 a2277638 0000000f
[10/31/2022 15:13:44.0590] 7ea0: 00677000 ffffffc0 7d4d4000 ffffffc0 00902000 ffffffc0 7ffc7b00 ffffffc0
[10/31/2022 15:13:44.0590] 7ec0: 00968b30 ffffffc0 7d4d7f10 ffffffc0 004750cc ffffffc0 7d4d7f10 ffffffc0
[10/31/2022 15:13:44.0590] 7ee0: 004750d4 ffffffc0 60000145 00000000
[10/31/2022 15:13:44.0590] [<ffffffc00008f49c>] secondary_start_kernel+0x124/0x148
[10/31/2022 15:13:44.0590] CPU3: stopping
[10/31/2022 15:13:44.0590] CPU: 3 PID: 1 Comm: systemd Tainted: P D O 4.1.52 #5
[10/31/2022 15:13:44.0590] Exception stack(0xffffffc07d483900 to 0xffffffc07d483a30)
[10/31/2022 15:13:44.0590] 3900: 00b04000 ffffffc0 00000000 00000080 7d483a50 ffffffc0 000de63c ffffffc0
[10/31/2022 15:13:44.0590] 3920: 00000871 00000000 000003e8 00000000 00008640 ffffff80 0049c580 ffffffc0
[10/31/2022 15:13:44.0590] 3940: 00000007 00000000 00000001 00000000 0049c478 ffffffc0 0090f600 ffffffc0
[10/31/2022 15:13:44.0590] 3960: 7d478640 ffffffc0 7d483920 ffffffc0 00000000 00000000 fefefeff fefefefe
[10/31/2022 15:13:44.0590] 3980: 56dfc2c2 00000055 00000000 00000000 90000000 00051c08 00000000 003b9aca
[10/31/2022 15:13:44.0590] 39a0: 001806d8 ffffffc0 84a2d0a0 0000007f 00000000 00000000 00b04000 ffffffc0
[10/31/2022 15:13:44.0590] 39c0: 00925000 ffffffc0 00000001 00000000 00affee0 ffffffc0 0000002c 00000000
[10/31/2022 15:13:44.0590] 39e0: 7d5898a8 ffffffc0 00000140 00000000 00020101 00000000 00aff000 ffffffc0
[10/31/2022 15:13:44.0590] 3a00: 0094e000 ffffffc0 7d483a50 ffffffc0 000de638 ffffffc0 7d483a50 ffffffc0
[10/31/2022 15:13:44.0590] 3a20: 000de63c ffffffc0 60000145 00000000
[10/31/2022 15:13:44.0590] [<ffffffc0000deee0>] console_device+0x70/0x80
[10/31/2022 15:13:44.0590] [<ffffffc0003bfc2c>] tty_open+0x29c/0x500
[10/31/2022 15:13:44.0590] [<ffffffc00018590c>] chrdev_open+0xb4/0x180
[10/31/2022 15:13:44.0590] [<ffffffc00017ee6c>] do_dentry_open+0x204/0x300
[10/31/2022 15:13:44.0590] [<ffffffc0001801e0>] vfs_open+0x58/0x68
[10/31/2022 15:13:44.0590] [<ffffffc00018ee80>] do_last+0x2f0/0xce0
[10/31/2022 15:13:44.0590] [<ffffffc00018f8f8>] path_openat+0x88/0x600
[10/31/2022 15:13:44.0590] [<ffffffc000191140>] do_filp_open+0x30/0x98
[10/31/2022 15:13:44.0590] [<ffffffc0001805c8>] do_sys_open+0x148/0x230
[10/31/2022 15:13:44.0590] [<ffffffc0001806e8>] SyS_openat+0x10/0x18
[10/31/2022 15:13:44.0590] Rebooting in 5 seconds..
Solved! Go to Solution.
ā11-08-2022 01:50 AM
Looks like you need to RMA. Reach out to TAC.
ā11-08-2022 01:58 AM
what is the model of the switch the AP connected ? and show power in line from the switch and check what power supplied to AP.
ā11-08-2022 02:15 AM - edited ā11-08-2022 02:16 AM
Connected to C9200L-24P-4G Switch and the show power inline show :
Gi1/0/2 auto on 11.0 Ieee PD 4 30
Switch is powering another 10 access points without problem
ā09-19-2024 12:35 PM
I am having the same issue with 2 cisco 9115AXI-B access points. The issue persists regardless of switch used (have tried several, 9200 switches and validated good ports with working APs.
the point of SySopenat(string of charactors)
is where the kerSysSoftReset: Called on ..... happens
