C9115AX on C2960X with Prime Infrastructure 3.10.1 and 5520WLC
danielcimpeanu
Hi gents,
I'm rather new to the wireless world and am in doubt in regards to device/software compatibility.
Environment I'm on is currently using 2802I-E-K9 access point behind C2960X switches and controlled by a 5520 WLC running 8.10.162; the plan is to adopt 9115AX access point behind Catalyst 9200L switches, all overseen through Prime Infrastructure 3.10.1 and ISE 3.0
The first step is updating 5520 WLC to 8.10.181.3 to accommodate for the 9115AX and keep the old 2802I running fine (thus avoiding issue described in 5520 WLC 8.10.181.3 - Cisco Community)
BUT.. due to delayed C9200L switch delivery I might need to attempt integrating the 9115AX behind older 2960X switches - in your experience would you expect any issues with running the 9115 through older C2960X in the described combination?
Daniel
marce1000
 - The older switch won't impact connectivity between the access point and the controller
 M.
Thanks for your fast reply!
