C9115AXI-EWC - Can't access management interface
Ingénierie RCI
Hi everyone,
I'm having a strange issue when setting up a 9800 EWC on a C9115.
When powering the EWC up and making the initial configuration through the CLI (putting IP, mask, gateway, ...) and saving it, I can't access the management interface.
The poe switch is an Aruba 2530-24G PoE+ and the controler connection port is configured in untagged vlan 1. No other vlan configuration on the switch.
What am I missing ?
Another question, on the same untagged interface, I'll have two IP addresses, the Controler and the AP, how does this work ?
Arshad Safrulla
Below is from a HP switch, Check whether this will help.
LAB-switch1(config)# vlan 1 (Management)
LAB-switch1(vlan-1)# untagged 1
LAB-switch1(config)# vlan 2 (Employee)
LAB-switch1(vlan-2)# tagged 1
LAB-switch1(config)# vlan 3 (Guest)
LAB-switch1(vlan-3)# tagged 1
thanks for your reply.
What about if I have only one vlan ? management and employee will be both in vlan 1 ?
Arshad Safrulla
Under the policy profile, Access policies select VLAN1
Under the Flex profile, General TB set Native VLAN as 1 & then under the VLAN tab add VLAN 1
