C9800-CL GUI not working
ANKUSH_SINGLA
Hello Guys,
i have build two new C9800-CL in SSO with code 17.6.
for some reason, my GUI is not working , only SSH is operational.
any help will be appreciated.
7 Replies 7
M02@rt37
Hello @ANKUSH_SINGLA,
HTTP and HTTPS services are enabled on the controller ?
Do yo test with an other browser ?
Best regards
Hi M02@rt37  i tried different browser same issue. yes i have http enable
wayzataoclab932-iwc#sh running-config | sec http
webauth-http-enable
no ip http server
ip http authentication aaa login-authentication default
ip http authentication aaa exec-authorization default
ip http authentication aaa command-authorization 15 default
ip http secure-server
ip http secure-trustpoint CISCO_IDEVID_SUDI
ip http client source-interface GigabitEthernet1
when i see trust point none of service is avilable.
wayzataoclab932-iwc#show wireless management trustpoint
Trustpoint Name :
Certificate Info : Not Available
Private key Info : Not Available
FIPS suitability : Not Applicable
Ok @ANKUSH_SINGLA , Do you try port 80 ?
then, "ip http server" to enable
Best regards
HM02@rt37 , both are allowed , but GUI is still not working.
OK @ANKUSH_SINGLA,
Does a telnet on port 80 or 443 from your PC to the IP management is OK?
Best regards
Mark Elsen
  - Have a checkup-review of your C9800-CL   controller configuration with the (through SSH) CLI command : show tech wireless  , have the output analyzed with : https://cway.cisco.com/wireless-config-analyzer
                                         Checkout all advisories!
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Rich R
Suggesting you go through the installation guide and best practices guide (below) to make sure you have not missed any steps.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/9800-cloud/installation/b-c9800-cl-install-guide/installing_the_controller.html
