c9800 Flex connect vlans help!
Hi All,
I am migrating a 5508 with Flex connect AP's at multiple sites to c9800cl.  Many AP's are connected to non-trunk ports with 'switchport access vlan X' and in the WLC those AP's/Flex groups have 'vlan support' unchecked, with no native vlan or vlan/mappings' set at all.  Basically all traffic ends up using the access port VLAN X at each site.
It seems I must enter values in the Policy/Flex profiles and haven't found a way to just uncheck 'vlan support'.  What is the easiest way to do this on the c9800?
Policy Profile - VLAN = ?   (do I have to set to VLAN X?)
Flex Profile  - Native VLAN ID = ?  (do I also have to set to VLAN X)
Flex Profile - VLAN tab =  (do I need to create VLAN X?)
Scott Fella
This is the document that I have used to deploy FlexConnect on a 9800-L
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213945-understand-flexconnect-on-9800-wireless.html#anc8
Since your AP’s are on an access vlan, that is what you would put as your native vlan.
-Scott
Tobias Heisele
Policy Profile - VLAN-NAME --> just a parameter, no relation to vlans on the c9800 (see Flex Profile below). Could be "Policy1sFlexVlan"
Flex Profile  - Native VLAN ID = x --> it can be the same than on the switch, but since it is untagged, choose whatever you like
Flex Profile - Mapping from VLAN-Name (from Policy Profile i.e. "Policy1sFlexVlan") to VLAN-ID x (when identical to native vlan id, packets will be untagged. Again - no need to match the switch access vlan id (but better for troubleshooting)
