02-08-2022 02:50 AM
Hello Team,
Kindly advise me which cable can use to power the IW3702-2E-E-K9 AP using a POE switch?
I was wondering if the normal RJ45 will do?
Also, as a second option which power injector will work, the customer is based in South Africa.
Thanks.
Solved! Go to Solution.
02-08-2022 05:09 AM - edited 02-08-2022 05:17 AM
Normal RJ45 will not work. You need shielded cable with M12 X-Code connector at the AP side. Even if you use standard POE adapter make sure that POE adapter is POE+ or UPOE capable, and you terminate the AP side to M12-X code connector. For inline power you need POE+ or UPOE capable switches.
Installation guide is very comprehensive.
Cisco IW3702 Access Point Getting Started Guide - Cisco
More info on the connector
https://eu.mouser.com/new/te-connectivity/te-m12-x-code-field-installable-connectors/
02-08-2022 02:57 AM
What environmental elements will the cable be exposed to?
02-08-2022 03:25 AM
@Leo Laohoo Is a mining area.
I think I did not pose the question correctly. The first question is, can the AP use a normal RJ45?
Then the 2nd will be for a mining area which cable will be best for that kind of environment?
02-08-2022 04:02 AM
For mining look for industrial-grade cables which can tolerate high temperature, humidity, a lot of dusts and constant vibration.
And do not skimp on the cost of a cable. The cheaper the cable, the higher the chance of failure.
02-08-2022 06:02 AM
Thank you so much for your responses, much appreciated!
This answered my questions.
02-08-2022 05:14 AM - edited 02-08-2022 05:24 AM
In a strictly theoretical world, the following is true about PoE:
- PoE - Cat3 or above needed - 100m
- PoE+ - Cat5 or above needed - 100m
- PoE++ - Cat5 or above needed - 100m
Past these lengths, PoE injectors are needed.
All of these use the R45 plug (as fibre can't provide PoE)
However, in the real world, the environment you have referred to, I would 100% recommend some shielded (STP) cable that is at least Cat6 to stop any interference from various mining equipment. I massively agree with @Leo Laohoo here and make sure to use high-quality cable. That cheap stuff just will not cut it here.
**Edit**
Apologies, I had not fully clocked the model of AP. Yes, a normal RJ45 type connector will not plug into the AP. It needs to be the M12 X code connector.
Hope this helps you out!
Tim
02-08-2022 06:04 AM
Thank you so much for your response. Helpful!
