06-10-2014 03:43 PM - edited 07-05-2021 12:59 AM
Hi All.
I've been crawling over this issue for too long - I need your help. Thanks for whatever time you can give this.
Problem:
Users of the 7925 phones get a "network busy" message and are unable to make phone calls.
Config:
Code: 7.4.121
Supported data rates: 12 Mbps and greater. (6 is disabled)
Mandatory data rate: 24 Mbps
802.11a > Media > VOICE
CAC Stats:
WMM TSPEC CAC Call Stats
Total num of Calls in progress................. 6
Num of Roam Calls in progress.................. 19617
Total Num of Calls Admitted.................... 29790
Total Num of Roam Calls Admitted............... 14145
Total Num of exp bw requests received.......... 0
Total Num of exp bw requests Admitted.......... 0
Total Num of Calls Rejected.................... 14141
Total Num of Roam Calls Rejected............... 13367
Num of Calls Rejected due to insufficent bw.... 1
Num of Calls Rejected due to invalid params.... 4
Num of Calls Rejected due to PHY rate.......... 13402
Num of Calls Rejected due to QoS policy........ 734
CAC Stats for AP in Problematic AreaTemporary Solution:
Call Admission Control (CAC) Stats
Voice Bandwidth in use(% of config bw)......... 2
Voice Roam Bandwidth in use(% of config bw).... 0
Total channel MT free........................ 26686
Total voice MT free.......................... 23811
Na Direct.................................... 24
Na Roam...................................... 27
Video Bandwidth in use(% of config bw)......... 0
Video Roam Bandwidth in use(% of config bw).... 0
Total BW in use for Voice(%)................... 2
Total BW in use for SIP Preferred call(%)...... 0
Total num of voice calls in progress........... 1
Num of roaming voice calls in progress......... 416
Total Num of voice calls since AP joined....... 4099
Total Num of roaming calls since AP joined..... 1954
Total Num of exp bw requests admitted.......... 0
Num of voice calls rejected since AP joined.... 1361
Num of roam calls rejected since AP joined..... 1357
Num of calls rejected due to insufficent bw.... 0
Num of calls rejected due to invalid params.... 1
Num of calls rejected due to PHY rate.......... 1360
Num of calls rejected due to QoS policy........ 0
If I am reading this correctly it rejects about 1/5 of all calls attempted. Seems unacceptable, right?
Channel Utilization of AP in Problem Area
(Cisco Controller) >show 802.11a cu-metrics 125
AP Interface Mac: 6c:9c:ed
Measurement Duration: 90sec
Timestamp Tue Jun 10 14:56:16 2014
Channel Utilization stats
Picc (50th Percentile)...................... 0
Pib (50th Percentile)....................... 1
Picc (90th Percentile)...................... 0
Pib (90th Percentile)....................... 2
Timestamp Tue Jun 10 15:09:56 2014
--More-- or (q)uit
Pib (90th Percentile)....................... 1
Timestamp Tue Jun 10 15:32:44 2014
Timestamp Tue Jun 10 14:48:40 2014
Pib (50th Percentile)....................... 0
Timestamp Tue Jun 10 14:51:42 2014
--More-- or (q)uit
Timestamp Tue Jun 10 14:53:13 2014
Timestamp Tue Jun 10 14:54:44 2014
Temporary Solution:
Disable CAC. This will stop the network busy messages and allow the phones to make calls with some degradation.
Anyway, thanks again for looking through this.
06-11-2014 05:16 AM
Verify all these process
When using a controller, add the following QoS policies:
Platinum (voice)—Apply this policy to your voice WLAN SSID/VLAN for both incoming and outgoing traffic
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7925g/7_0/english/administration/guide
06-11-2014 08:08 AM
Thank you for your response. Platinum voice is being used. These are 5508 controllers, so should I still be using global RF settings?
I am now suspicious that the problem exists between APs with an RF profile and APs using global RF settings. Looks like the difference is that the same SSID exists, with different minimum data rates.
Would that cause a network busy?
06-11-2014 09:28 PM
HTML into the phone and confirm 12 Mbps is supported.
