03-16-2016 12:05 AM - edited 07-05-2021 04:47 AM
Can I setup Cisco AP 1532/1552 with 5 GHz omni antenna and 2.4 directional antenna?
03-16-2016 02:32 AM
Yes you can but.......I will not recommend to use the mix antenna.
Don't forget to rate helpful posts
03-16-2016 10:06 PM
Hi Sandeep,
Thanks for quick response.
But please reference doc.
Very much thanks and regards,
Zarni
