Can we use AIR-AP1142N-A-K9 for India Domain
vikaskohli2
Hi ,
Can we use AIR-AP1142N-A-K9  for India Domain ? , as per the compliances it is –N .
What is the   technical difference between AIR-AP1142N-A-K9  and AIR-AP1142N-N-K9, both the AP  configuration guides are same
will it work or not ?
Stephen Rodriguez
You can, but you need to be careful.
nostringsattachedshow.com/2012/02/02/multiple-country-codes-with-the-cisco-wlc/
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
