I am new to Cisco gear and am trying to set up and test an Aironet 1200 running 'g' wireless backwards compatible with our 'b' users. If I turn on SSID broadcast my 'g' laptop sees it and connects automatically. If SSID broadcast is turned off the laptop cannot find the SSID, and will not even connect manually.
I am puzzled. My Netgear access point at home has broadcast off but the laptop connects automatically every time. So do other access points I have used.
We are running System Software 12.2(13)JA2. The laptops are all IBM Thinkpads, (T30's and T40's). I have set the AP for Open Authentication w/ MAC, and the MAC addresses are in the list. It works perfectly with broadcast on; I just do not want to broadcast our SSID around the entire industrial park.
I saw in a posting abour "Cisco Extensions" enabled can cause problems. Could this be it?
Thanks for any suggestions any of you can make.
