Cannot get netflow data from wireless controller
Mark Elsen
Platform : WLC5508/ Software version : 8.0.133.0
In my config I have
config flow add monitor public exporter netadm
config flow create exporter netadm 10.48.1.60 port 23458
Yet I don't get any netflow data from the controller on the designated host/port.
                Do I need something else or 'more' ?
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rasika Nayanajith
Have you configured AVC profile and enable it on your SSID. Refer below post
https://mrncciew.com/2013/02/12/configuring-netflow-on-wlc-7-4/
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
    - Not yet, I only did the netflow part, thanks for this usefull infomation.
M.
