Cant connect client capable wifi 6 to protocol 802.11ax in EWC C9120AX
sonic1111
spec C9120AXI-F
EWC 17.6.1
client iphone 12 pro max and ipad pro m1 setting disable private address
problem can’t connect to protocol 802.11AX / wifi 6 and 80mhz channel in ac slow throughput test in iperf3 130mbps with server connect to cabel 1gb port switch
please Help
8 Replies 8
Leo Laohoo
Downgrade to 17.3.4 and try again.
I've changed it to 17.3.4 and the result is the same the iphone 12 pro or ipad pro m1 connect to 802.11ac protocol
MAC Address
f02f.4bdc.c6ec
Client MAC Type
Universally Administered Address
IPV4 Address
192.168.1.150
IPV6 Address
fe80::d8:a624:2183:1b49
User Name
N/A
Policy Profile
CiscoAX
Flex Profile
default-flex-profile
Wireless LAN Id
WLAN Profile Name
CiscoAX
Wireless LAN Network Name (SSID)
CiscoAX
BSSID
1416.9db2.542f
Uptime(sec)
260 seconds
Idle state timeout
N/A
Session Timeout
86400 sec (Remaining time: 86141 sec)
Session Warning Time
Timer not running
Client Active State
Active
Power Save mode
ON
Current TxRateSet
m8 ss2
Supported Rates
18.0,36.0,48.0,54.0
Join Time Of Client
09/03/2021 15:40:49 UTC
Client State Servers
None
Client ACLs
None
Policy Manager State
Run
Last Policy Manager State
IP Learn Complete
AAA override passphrase
No
User Defined (Private) Network
Disabled
User Defined (Private) Network Drop Unicast
Disabled
Encrypted Traffic Analytics
No
VLAN Override after Webauth
No
VLAN
default
Multicast VLAN
WiFi Direct Capable
No
Central NAT
DISABLED
11v DMS Capable
Yes
11v DMS ID Mask
0x0
QoS Map Capable
No
FlexConnect Data Switching
Local
FlexConnect DHCP Status
Local
FlexConnect Authentication
Central
FlexConnect Central Association
No
Capabilities
Link Measurement, Passive Beacon Measurement, Active Beacon Measurement, Statistics Measurement, AP Channel Report
Client Scan Report Time
Timer not running
Last Report @
09/03/2021 15:40:49
Device Name
Unknown Device
Max Client Protocol Capability
802.11ac Wave 2
Cellular Capability
N/A
Confidence Level
General
AP Name
C9120AX
IP Address
192.168.1.101
AP Mode
FlexConnect
MAC Address
1416.9db2.5420
Number of Slots
Radio Type
802.11ax - 5 GHz
Slot ID
Subband Type
All
11ax Parameters
802.11ax Enabled
Yes
HE Capable
Yes
MultiBssid
Supported
BSS Color Capable
Yes
BSS Color Configuration
Automatic
Current BSS Color
53
Load Information
Load Profile
Passed
Receive Utilization (%)
Transmit Utilization (%)
Channel Utilization (%)
Traffic Utilization (%)
Coverage Information
Coverage Profile
Passed
Interference Profile
Passed
Tx rate (bps)
2693948
Rx rate (bps)
504
Data rate (bps)
2694452
High Density
Multicast Data Rate (Mbps)
Auto
Rx Sop Threshold (dbm)
Auto (0 dbm)
What is the objective of this exercise?  Is it to prove the wireless clients able to "hit" 802.11ax speed or to connect only to 802.11ax protocol?
To connect wifi 6 802.11ax protocol
because hardware ap and client is capable to run wifi 6 protocol
thanks you for you reply
802.11ac Wave 2
Not sure why the AP is detecting the wireless client to only support 802.11ac.
I am not really familiar with eWLC but have a look at this guide (Configuring 11AX) and see this helps.
JPavonM
That could be one of two issues, or this is a cosmethic issue on the IOS-XE software (I've found that with certain codes COS-APs shows 2 spatial strrams clients connecting with 2 streams but using MCS Index for 1ss in the WLC CSCvx54426) or this is a defect on the M1 side as it happened on early stages with driver firmware and some 802.11 features on MacBooks.
-Jesus
*** Please rate helpful responses ***
sonic1111
update
I tested with client samsung s20 it show 80.211ax protocol with c9120ax 17.6.1 EWLC
in my opinion there are two possible incompatibility of ipad m1 driver and cisco 9120 software
