Capture aborted without reason
Meraki-User-713
Community Member
We have launched two captures filtering with customer MAC address.
The result is the same: the capture is stopped witouth reason.
9 Replies 9
aleabrahao
Meraki Community All-Star
Have you tried with another browser? If so, I suggest you open a support case.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
Meraki-User-713
Community Member
Yes, captures have been made with two differents browsers.
Raphael_L
Unless I don't understand your question , you have specified a 3600s capture duration and you have reach the limit. That's probably why it stopped.
Meraki-User-713
Community Member
I have made the test with another duration (1200).
In both cases, I do not retrieve pcap files.
Raphael_L
Your filter expression won't work on wireless interfaces.
Meraki-User-713
Community Member
Thanks for your reply Raphael.
You have reason ... my bad 😅
joey.debra
You could try actual wireless capture filters.
With some luck you could filter your mac address if it is the transmitter or receiver address by using following filter.
wlan addr1 <mac address> or wlan addr2 <same mac address>
Meraki-User-713
Community Member
Thanks for the wireless capture filter given.
Meraki-User-713
Community Member
I finally launched capture with no filter and put a filter in Wireshark.
