capturing lwapp data frames
sebastiaannoppe
I have trouble capturing lwapp data frames. I have AP on port 1, i have instructed my switch (3750) to monitor this port and send it to a available port on the same switch (no stacking). On the second port , i connect my sniffer. I see lwapp control frames (RRM,ect) , keepalives and 802.11 assoc frames, however, i do not see the encapsulated data frames. I need to see those to know that my end to end qos tagging is working properly.
traces with wireshark.
Any ideas ?
mark.cronin
Level 5
Level 5
Are you using the AP in H-REAP mode?
Nope, standard lwapp deployment.
In the meantime i have found a workaround using a hub. Attach the hub on the switch, then the ap on the hub and presto you can see all packets.
Seems to be a limitation of monitor ...
Anyone can confirm it ?
