Capwap 1852 mobility express upgrade issue
Debudas123
 I have 23 nos of CAP1852E, i want to convert the ap to mobility express through tftp.
I have execute the command - #ap-type mobility-express tftp://x.x.x.x/AIR-AP1850-K9-8.3.102.0.tar
it will showing the error " curl: (68) getpeername() failed with errno 107: Transport endpoint is not connected "
and unable to download the iOS.
can please help us ?
Debabrata Das
7 Replies 7
Rasika Nayanajith
Have a look below post & see you follow correct procedure
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-5/b_cisco_mobility_express_8_5/b_cisco_mobility_express_8_5_chapter_01.html
Here is a blog post explain each steps simply.
https://www.semfionetworks.com/blog/convert-a-cisco-capwap-ap-to-a-mobility-express-ap
Rasika
*** Pls rate all useful responses ***
 I am following the that you mentioned, but same error is coming.
Debabrata
Did you ever resolve this issue?  I am running into the same error.
Just change the system where tftp server is installed.
Debabrata Das
Where to move the system tftp
sjhrhaskell
Check your TFTP server file permissions.  This error can be the result of an access violation regarding the specific file.  Make sure all users have read access to the file.
Matias Acuna
in my case, i changed the pc where tftp server was located, and it's worked fine
