CAPWAP/DTLS Handshake Error Joining Cisco 2802i AP to 5508 WLC
Rafael Rubik
Hello friends,
I tried to join a Cisco 2802i AP to a 5508 WLC but found an issue that is not allowing it joining successfully. I believe the problem occurs in capwap / dtls handshake (CAPWAP State "Configure").
Some details:
. We have 170 sites
. We have 4 5508 WLCs
. The problem only occurs on a new site that we are deploying
. This site ( 1x 4431 ISR, 1x 3560CX-12PC-S, 3x 2802i )
. We already changed the router, switch, ap, trunk cable, electrical outlet.
. We already installed a new MPLS circuit (we are the nw operator)
. I took the switch and AP to another site and everything worked fine.
. There is no firewall between this site and the wlc (WLC-1) we are testing.
. There is a firewall for 3 other WLCs (WLC-2, 3, 4) but the log shows "passed" for all traffic.
Some debugs:
(Cisco Controller) debug>capwap errors enable
(Cisco Controller) debug>*spamApTask1: Dec 03 17:44:54.194: 10:b3:d5:3a:81:00 Unable to get Ap mode in Join request
*spamReceiveTask: Dec 04 09:59:42.286: 50:3e:aa:d4:63:ca Unable to get RadId. Sending of PMK cache entry to all APs in flexconnect group failed :: bssid 00:00:00:00:00:00
*spamReceiveTask: Dec 04 09:59:45.881: 70:0b:4f:7b:d3:8d Unable to get RadId. Sending of PMK cache entry to all APs in flexconnect group failed :: bssid 00:00:00:00:00:00
*spamReceiveTask: Dec 04 09:59:50.552: 70:c9:c6:4b:55:1c Unable to get RadId. Sending of PMK cache entry to all APs in flexconnect group failed :: bssid 00:00:00:00:00:00
*spamReceiveTask: Dec 04 10:00:14.064: a4:4e:31:ba:93:08 Unable to get RadId. Sending of PMK cache entry to all APs in flexconnect group failed :: bssid 00:00:00:00:00:00
*spamReceiveTask: Dec 04 10:00:19.434: 5c:cd:5b:20:5a:e9 Unable to get RadId. Sending of PMK cache entry to all APs in flexconnect group failed :: bssid 00:00:00:00:00:00
*spamApTask1: Dec 04 10:00:19.986: 10:b3:d5:3a:81:00 DTLS connection was closed
*spamApTask1: Dec 04 10:00:25.792: 10:b3:d5:3a:81:00 ApModel: AIR-AP2802I-Z-K9
*spamApTask1: Dec 04 10:00:25.810: 10:b3:d5:3a:81:00 ApModel: AIR-AP2802I-Z-K9
*spamApTask1: Dec 04 10:00:35.622: 10:b3:d5:3a:81:00 Unable to get Ap mode in Join request
*spamReceiveTask: Dec 04 10:00:46.339: 80:86:f2:fc:a5:0d Unable to get RadId. Sending of PMK cache entry to all APs in flexconnect group failed :: bssid 00:00:00:00:00:00
*spamApTask1: Dec 04 10:01:18.525: 10:b3:d5:3a:81:00 DTLS connection was closed
*spamApTask1: Dec 04 10:01:24.336: 10:b3:d5:3a:81:00 ApModel: AIR-AP2802I-Z-K9
debug capwap events
*spamApTask4: Dec 04 10:15:41.531: a0:93:51:fc:b2:c0 Echo Request from 10.15.25.12:5272
*spamApTask4: Dec 04 10:15:41.531: a0:93:51:fc:b2:c0 Echo Response sent to 10.15.25.12:5272
*spamApTask4: Dec 04 10:16:00.111: a0:93:51:fc:b2:c0 WTP Event Request from 10.15.25.12:5272 epoch 1607087760
*spamApTask4: Dec 04 10:16:00.111: a0:93:51:fc:b2:c0 WTP Event Response sent to 10.15.25.12:5272
*spamApTask4: Dec 04 10:16:00.125: a0:93:51:fc:b2:c0 WTP Event Request from 10.15.25.12:5272 epoch 1607087760
*spamApTask4: Dec 04 10:16:00.125: a0:93:51:fc:b2:c0 WTP Event Response sent to 10.15.25.12:5272
*spamApTask4: Dec 04 10:16:03.996: a0:93:51:fc:b2:c0 WTP Event Request from 10.15.25.12:5272 epoch 1607087763
*spamApTask4: Dec 04 10:16:03.996: a0:93:51:fc:b2:c0 WTP Event Response sent to 10.15.25.12:5272
*spamApTask1: Dec 04 10:16:16.042: 10:b3:d5:3a:81:00 acDtlsPlumbControlPlaneKeys: lrad:10.15.102.14(5248) mwar:10.15.152.5(5246)
*spamApTask1: Dec 04 10:16:16.042: 10:b3:d5:3a:81:00 DTLS keys for Control Plane deleted successfully for AP 10.15.102.14
*spamApTask1: Dec 04 10:16:16.043: 10:b3:d5:3a:81:00 DTLS connection closed event receivedserver (10.15.152.5/5246) client (10.15.102.14/5248)
*spamApTask1: Dec 04 10:16:16.043: 10:b3:d5:3a:81:00 Entry exists for AP (10.15.102.14/5248)
*spamApTask1: Dec 04 10:16:16.043: 10:b3:d5:3a:81:00 Capwap State Change Event (DeReg) from capwap_ac_sm.c 1787
*spamApTask1: Dec 04 10:16:16.044: 10:b3:d5:3a:81:00 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 10:b3:d5:3a:81:00 slot 0
*apfReceiveTask: Dec 04 10:16:16.044: 10:b3:d5:3a:81:00 Deregister LWAPP event for AP 10:b3:d5:3a:81:00 slot 0
*spamApTask1: Dec 04 10:16:16.044: 10:b3:d5:3a:81:00 Capwap State Change Event (DeReg) from capwap_ac_sm.c 1787
*spamApTask1: Dec 04 10:16:16.044: 10:b3:d5:3a:81:00 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 10:b3:d5:3a:81:00 slot 1
*spamApTask1: Dec 04 10:16:16.044: 10:b3:d5:3a:81:00 AP Delete request
*apfReceiveTask: Dec 04 10:16:16.044: 10:b3:d5:3a:81:00 Deregister LWAPP event for AP 10:b3:d5:3a:81:00 slot 1
*spamApTask1: Dec 04 10:16:16.045: 10:b3:d5:3a:81:00 No AP entry exist in temporary database for 10.15.102.14:5248
*spamApTask1: Dec 04 10:16:21.854: 10:b3:d5:3a:81:00 Discovery Request from 10.15.102.14:5248
debug dtls all
*capwapSocketTask: Dec 04 10:20:07.737: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a528e20
*capwapSocketTask: Dec 04 10:20:07.737: 10:b3:d5:3a:81:00 Releasing lock for 0x1a528e20
*capwapSocketTask: Dec 04 10:20:07.737: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.14:5248
*capwapSocketTask: Dec 04 10:20:12.488: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.14:5248
*capwapSocketTask: Dec 04 10:20:12.488: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a528e20
*capwapSocketTask: Dec 04 10:20:12.488: 10:b3:d5:3a:81:00 Releasing lock for 0x1a528e20
*spamApTask1: Dec 04 10:20:17.240: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.14:5248
*spamApTask1: Dec 04 10:20:17.240: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a528e20
*spamApTask1: Dec 04 10:20:17.240: 10:b3:d5:3a:81:00 Called... for connection 0x1a528e20
*spamApTask1: Dec 04 10:20:17.240: 10:b3:d5:3a:81:00 Buffer length 61, alloc_len 65
*spamApTask1: Dec 04 10:20:17.240: 10:b3:d5:3a:81:00 record=Alert epoch=1 seq=29
*spamApTask1: Dec 04 10:20:17.240: 10:b3:d5:3a:81:00 handshake_done
*spamApTask1: Dec 04 10:20:17.240: 10:b3:d5:3a:81:00 con->rx_seq_valid 255 con->rx_epoch 1 epoch 1
*spamApTask1: Dec 04 10:20:17.240: 10:b3:d5:3a:81:00 seq_num 29 epoch 1con->rx_seq 0 con->rx_epoch 1
*spamApTask1: Dec 04 10:20:17.240: 10:b3:d5:3a:81:00 con rx_seq_valid 255 rx_seq 0 rx_epoch 1
*spamApTask1: Dec 04 10:20:17.240: 10:b3:d5:3a:81:00 Got DTLS_RECORD_ALERT
*spamApTask1: Dec 04 10:20:17.240: 10:b3:d5:3a:81:00 record length 48
*spamApTask1: Dec 04 10:20:17.240: 00000000: 15 fe fd 00 01 00 00 00 00 00 1d 00 30 d9 7d 31 ............0.}1
*spamApTask1: Dec 04 10:20:17.240: 10:b3:d5:3a:81:00 Calling BIO_write! 0x1a528e20, buflen 61
*spamApTask1: Dec 04 10:20:17.241: openssl_shim_info_callback: SSL state = 0x3; where = 0x4004; ret = 0x100
*spamApTask1: Dec 04 10:20:17.241: openssl_shim_info_callback: ret_type_string=warning
*spamApTask1: Dec 04 10:20:17.241: openssl_shim_info_callback: ret_desc_string=close notify
*spamApTask1: Dec 04 10:20:17.241: openssl_shim_info_callback: SSL_state_string=SSL negotiation finished successfully
*spamApTask1: Dec 04 10:20:17.241: 10:b3:d5:3a:81:00 SSL_read: peer 10.15.102.14 has closed the connection
*spamApTask1: Dec 04 10:20:17.241: 10:b3:d5:3a:81:00 Requested by openssl_dtls_process_packet
*spamApTask1: Dec 04 10:20:17.241: 10:b3:d5:3a:81:00 in openssl_dtls.c:1032
*spamApTask1: Dec 04 10:20:17.241: 10:b3:d5:3a:81:00 Deleting hash for Local 10.15.152.5:5246 Peer 10.15.102.14:5248
*spamApTask1: Dec 04 10:20:17.241: 10:b3:d5:3a:81:00 Called...
*spamApTask1: Dec 04 10:20:17.241: openssl_shim_info_callback: SSL state = 0x3; where = 0x4008; ret = 0x100
*spamApTask1: Dec 04 10:20:17.241: 10:b3:d5:3a:81:00 Shutdown completed
*spamApTask1: Dec 04 10:20:17.241: 10:b3:d5:3a:81:00 Sending 61 bytes
*spamApTask1: Dec 04 10:20:17.241: 00000000: 15 fe fd 00 01 00 00 00 00 00 01 00 30 64 af dd ............0d..
*spamApTask1: Dec 04 10:20:17.241: 00000010: f5 21 d8 cb 6e 9b a1 86 bd 1c 1a 02 a6 72 bf e1 .!..n........r..
*spamApTask1: Dec 04 10:20:17.241: 00000020: 68 b1 60 d0 73 5b f7 af a8 3f 39 01 39 3e b9 07 h.`.s[...?9.9>..
*spamApTask1: Dec 04 10:20:17.241: 00000030: 86 f4 4b 24 0e a4 e6 53 a4 78 79 25 5f ..K$...S.xy%_
*spamApTask1: Dec 04 10:20:17.241: 10:b3:d5:3a:81:00 No data to send
*spamApTask1: Dec 04 10:20:17.242: 10:b3:d5:3a:81:00 DTLS Connection 0x1a528e20 closed by controller
*spamApTask1: Dec 04 10:20:17.243: __dtls_timer_stop: Called...
AP Logging (loop)
kernel: [*12/04/2020 13:56:32.5816] CAPWAP State: Configure
Dec 4 13:56:32 kernel: [*12/04/2020 13:56:32.5838] DOT11_CFG[0] Radio Mode is changed from FlexConnect to FlexConnect
Dec 4 13:56:32 kernel: [*12/04/2020 13:56:32.5873] DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
Dec 4 13:56:37 kernel: [*12/04/2020 13:56:37.3211] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:56:42 kernel: [*12/04/2020 13:56:42.0725] Re-Tx Count=2, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:56:46 kernel: [*12/04/2020 13:56:46.8240] Re-Tx Count=3, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:56:51 kernel: [*12/04/2020 13:56:51.5754] Re-Tx Count=4, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:56:56 kernel: [*12/04/2020 13:56:56.3269] Re-Tx Count=5, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:57:01 kernel: [*12/04/2020 13:57:01.0782] Re-Tx Count=6, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:57:05 kernel: [*12/04/2020 13:57:05.8297] Re-Tx Count=7, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:57:10 kernel: [*12/04/2020 13:57:10.5811] Re-Tx Count=8, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:57:15 kernel: [*12/04/2020 13:57:15.3324] Re-Tx Count=9, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:57:15 kernel: [*12/04/2020 13:57:15.3325]
Dec 4 13:57:15 kernel: [*12/04/2020 13:57:15.3325] Max retransmission count exceeded, going back to DISCOVER mode.
Dec 4 13:57:15 kernel: [*12/04/2020 13:57:15.3331]
Dec 4 13:57:15 kernel: [*12/04/2020 13:57:15.3331] CAPWAP State: DTLS Teardown
Dec 4 13:57:21 kernel: [*12/04/2020 13:57:21.1692] Discovery Response from 10.15.224.5
Dec 4 13:57:21 kernel: [*12/04/2020 13:57:21.1768] Discovery Response from 10.15.152.5
Dec 4 13:57:21 kernel: [*12/04/2020 13:57:21.1841] Discovery Response from 10.4.24.25
Dec 4 13:57:21 kernel: [*12/04/2020 13:57:21.1912] Discovery Response from 10.4.8.25
Dec 4 13:57:21 kernel: [*12/04/2020 13:57:21.1984] Discovery Response from 10.15.224.5
Dec 4 13:57:21 kernel: [*12/04/2020 13:57:21.2056] Discovery Response from 10.15.152.5
Dec 4 13:57:21 kernel: [*12/04/2020 13:57:21.2127] Discovery Response from 10.4.24.25
Dec 4 13:57:21 kernel: [*12/04/2020 13:57:21.2198] Discovery Response from 10.4.8.25
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.0000]
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.0000] CAPWAP State: DTLS Setup
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.4327]
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.4327] CAPWAP State: Join
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.4342] Sending Join request to 10.15.152.5 through port 5248
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.4467] Join Response from 10.15.152.5
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.5422]
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.5422] CAPWAP State: Image Data
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.5796] do NO_UPGRADE, part1 is active part
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.5830]
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.5830] CAPWAP State: Configure
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.5851] DOT11_CFG[0] Radio Mode is changed from FlexConnect to FlexConnect
Dec 4 13:57:31 kernel: [*12/04/2020 13:57:31.5857] DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
Dec 4 13:57:36 kernel: [*12/04/2020 13:57:36.3211] Re-Tx Count=1, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:57:41 kernel: [*12/04/2020 13:57:41.0726] Re-Tx Count=2, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:57:45 kernel: [*12/04/2020 13:57:45.8239] Re-Tx Count=3, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:57:50 kernel: [*12/04/2020 13:57:50.5754] Re-Tx Count=4, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:57:55 kernel: [*12/04/2020 13:57:55.3268] Re-Tx Count=5, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:58:00 kernel: [*12/04/2020 13:58:00.0782] Re-Tx Count=6, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:58:04 kernel: [*12/04/2020 13:58:04.8297] Re-Tx Count=7, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:58:09 kernel: [*12/04/2020 13:58:09.5811] Re-Tx Count=8, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:58:14 kernel: [*12/04/2020 13:58:14.3325] Re-Tx Count=9, Max Re-Tx Value=8, SendSeqNum=1, NumofPendingMsgs=1
Dec 4 13:58:14 kernel: [*12/04/2020 13:58:14.3325] Max retransmission count exceeded, going back to DISCOVER mode.
I've been working on this for several days, without success. Some help please.
Tks
Rafael Rubik
26 Replies 26
debug dtls trace enable
can i see output of this debug?
Hello MHM,
sure, tks ! File attached.
sorry there is error message appear
"This widget could not be displayed"
I think this error from cisco community site,
so friend if you have something to me please send it as message.
MHM ok ...
*capwapSocketTask: Dec 07 13:47:52.115: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1d10
*capwapSocketTask: Dec 07 13:47:52.115: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1d10
*spamApTask4: Dec 07 13:47:56.874: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:47:56.874: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1d10
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 Called... for connection 0x1a4d1d10
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 Buffer length 61, alloc_len 65
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 record=Alert epoch=1 seq=120
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 handshake_done
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 con->rx_seq_valid 255 con->rx_epoch 1 epoch 1
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 seq_num 120 epoch 1con->rx_seq 0 con->rx_epoch 1
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 con rx_seq_valid 255 rx_seq 0 rx_epoch 1
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 Got DTLS_RECORD_ALERT
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 record length 48
*spamApTask4: Dec 07 13:47:56.875: 00000000: 15 fe fd 00 01 00 00 00 00 00 78 00 30 59 b6 75 ..........x.0Y.u
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 Calling BIO_write! 0x1a4d1d10, buflen 61
*spamApTask4: Dec 07 13:47:56.875: openssl_shim_info_callback: SSL state = 0x3; where = 0x4004; ret = 0x100
*spamApTask4: Dec 07 13:47:56.875: openssl_shim_info_callback: ret_type_string=warning
*spamApTask4: Dec 07 13:47:56.875: openssl_shim_info_callback: ret_desc_string=close notify
*spamApTask4: Dec 07 13:47:56.875: openssl_shim_info_callback: SSL_state_string=SSL negotiation finished successfully
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 SSL_read: peer 10.15.102.11 has closed the connection
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 Requested by openssl_dtls_process_packet
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 in openssl_dtls.c:1032
*spamApTask4: Dec 07 13:47:56.875: 10:b3:d5:3a:81:00 Deleting hash for Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:47:56.875: openssl_shim_info_callback: SSL state = 0x3; where = 0x4008; ret = 0x100
*spamApTask4: Dec 07 13:47:56.876: 10:b3:d5:3a:81:00 Shutdown completed
*spamApTask4: Dec 07 13:47:56.876: 10:b3:d5:3a:81:00 Sending 61 bytes
*spamApTask4: Dec 07 13:47:56.876: 10:b3:d5:3a:81:00 No data to send
*spamApTask4: Dec 07 13:47:56.876: 10:b3:d5:3a:81:00 DTLS Connection 0x1a4d1d10 closed by controller
*spamApTask4: Dec 07 13:47:56.877: __dtls_timer_stop: Called...
*spamApTask4: Dec 07 13:47:56.877: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1d10
*spamApTask4: Dec 07 13:47:56.878: dtls_conn_hash_search: Connection not found in hash table - Table empty.
*spamApTask4: Dec 07 13:48:12.453: dtls_conn_hash_search: Connection not found in hash table - Table empty.
*spamApTask4: Dec 07 13:48:12.453: a0:93:51:76:e2:92 Searching hash for Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:12.453: dtls_secret_pki_init: Called...
*spamApTask4: Dec 07 13:48:12.453: dtls_secret_pki_add_idcert: Called...
*spamApTask4: Dec 07 13:48:12.454: acDtlsCallback: Certificate installed for PKI based authentication.
*spamApTask4: Dec 07 13:48:12.455: dtls_timer_start: Called...
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 Called... for connection 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 Buffer length 160, alloc_len 164
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=0
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 con->rx_seq_valid 0 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 updated con with rx_seq_valid 255 rx_seq 0 rx_epoch 0
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 msg=ClientHello len=135 seq=0 frag_off=0 frag_len=135
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 Rcvd ClientHello in connStatus 0
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 Received unknown(1) in connStatus 0. processing...
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 ClientHello can be processed
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 msg_seq:0,msg_len:135,frag_len:135,frag_off: 0
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 Allow: ClientHello in status 0
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 Received ClientHello in connStatus 0.
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 record length 147
*spamApTask4: Dec 07 13:48:12.455: 00000000: 16 fe ff 00 00 00 00 00 00 00 00 00 93 01 00 00 ................
*spamApTask4: Dec 07 13:48:12.455: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d1f00, buflen 160
*spamApTask4: Dec 07 13:48:12.455: openssl_shim_info_callback: SSL state = 0x6000; where = 0x10; ret = 0x1
*spamApTask4: Dec 07 13:48:12.455: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:48:12.455: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:48:12.455: openssl_shim_info_callback: SSL_state_string=before/accept initialization
*spamApTask4: Dec 07 13:48:12.455: openssl_shim_info_callback: SSL state = 0x6000; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.455: openssl_shim_info_callback: SSL state = 0x2110; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.455: openssl_shim_info_callback: SSL_state_string=SSLv3 read client hello A
*spamApTask4: Dec 07 13:48:12.456: openssl_shim_info_callback: SSL state = 0x2113; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.456: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:48:12.456: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:48:12.456: openssl_shim_info_callback: SSL_state_string=DTLS1 write hello verify request A
*spamApTask4: Dec 07 13:48:12.456: openssl_shim_info_callback: SSL state = 0x2100; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.456: openssl_shim_info_callback: SSL_state_string=SSLv3 flush data
*spamApTask4: Dec 07 13:48:12.456: openssl_shim_info_callback: SSL state = 0x2111; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:48:12.456: openssl_shim_info_callback: SSL_state_string=SSLv3 read client hello B
*spamApTask4: Dec 07 13:48:12.456: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:48:12.456: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d1f00 in status 0
*spamApTask4: Dec 07 13:48:12.456: a0:93:51:76:e2:92 Sending 60 bytes
*spamApTask4: Dec 07 13:48:12.456: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:48:12.456: a0:93:51:76:e2:92 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 Called... for connection 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 Buffer length 192, alloc_len 196
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=1
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 seq_num 1 epoch 0con->rx_seq 0 con->rx_epoch 0
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 0 rx_epoch 0
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 msg=ClientHello len=167 seq=1 frag_off=0 frag_len=167
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 Rcvd ClientHello in connStatus 0
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 Received unknown(1) in connStatus 0. processing...
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 ClientHello can be processed
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 msg_seq:1,msg_len:167,frag_len:167,frag_off: 0
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 Allow: ClientHello in status 0
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 Received ClientHello in connStatus 0.
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 record length 179
*spamApTask4: Dec 07 13:48:12.466: 00000000: 16 fe ff 00 00 00 00 00 00 00 01 00 b3 01 00 00 ................
*spamApTask4: Dec 07 13:48:12.466: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d1f00, buflen 192
*spamApTask4: Dec 07 13:48:12.466: 00000000: e1 91 98 a2 c3 3d 95 3f ef d7 27 b2 5f c7 69 33 .....=.?..'._.i3
*spamApTask4: Dec 07 13:48:12.466: 00000010: 09 54 ed 0a .T..
*spamApTask4: Dec 07 13:48:12.466: openssl_shim_info_callback: SSL state = 0x2111; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.467: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:48:12.467: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:48:12.467: openssl_shim_info_callback: SSL_state_string=SSLv3 read client hello B
*spamApTask4: Dec 07 13:48:12.467: openssl_shim_info_callback: SSL state = 0x2130; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.467: openssl_shim_info_callback: SSL_state_string=SSLv3 write server hello A
*spamApTask4: Dec 07 13:48:12.467: openssl_shim_info_callback: SSL state = 0x2140; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.467: openssl_shim_info_callback: SSL_state_string=SSLv3 write certificate A
*spamApTask4: Dec 07 13:48:12.467: openssl_shim_info_callback: SSL state = 0x2160; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.467: openssl_shim_info_callback: SSL_state_string=SSLv3 write certificate request A
*spamApTask4: Dec 07 13:48:12.467: openssl_shim_info_callback: SSL state = 0x2170; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.468: openssl_shim_info_callback: SSL_state_string=SSLv3 write server done A
*spamApTask4: Dec 07 13:48:12.468: openssl_shim_info_callback: SSL state = 0x2100; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.468: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:48:12.468: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:48:12.468: openssl_shim_info_callback: SSL_state_string=SSLv3 flush data
*spamApTask4: Dec 07 13:48:12.468: openssl_shim_info_callback: SSL state = 0x2180; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:48:12.468: openssl_shim_info_callback: SSL_state_string=SSLv3 read client certificate A
*spamApTask4: Dec 07 13:48:12.468: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:48:12.468: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d1f00 in status 0
*spamApTask4: Dec 07 13:48:12.468: a0:93:51:76:e2:92 Sending 544 bytes
*spamApTask4: Dec 07 13:48:12.468: a0:93:51:76:e2:92 Sending 333 bytes
*spamApTask4: Dec 07 13:48:12.468: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:48:12.468: a0:93:51:76:e2:92 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 Called... for connection 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 Buffer length 544, alloc_len 548
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=2
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 seq_num 2 epoch 0con->rx_seq 1 con->rx_epoch 0
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 1 rx_epoch 0
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 msg=Certificate len=893 seq=2 frag_off=0 frag_len=519
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 Rcvd Certificate in connStatus 0
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 Received unknown(11) in connStatus 0. processing...
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 Certificate can be processed
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 msg_seq:2,msg_len:893,frag_len:519,frag_off: 0
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 Allow: Certificate in status 0
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 Received Certificate in connStatus 0.
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 record length 531
*spamApTask4: Dec 07 13:48:12.479: 00000000: 16 fe fd 00 00 00 00 00 00 00 02 02 13 0b 00 03 ................
*spamApTask4: Dec 07 13:48:12.479: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d1f00, buflen 544
*spamApTask4: Dec 07 13:48:12.479: openssl_shim_info_callback: SSL state = 0x2180; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:48:12.479: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:48:12.479: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:48:12.479: openssl_shim_info_callback: SSL_state_string=SSLv3 read client certificate A
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d1f00 in status 0
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 Called... for connection 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 Buffer length 399, alloc_len 403
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=3
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 seq_num 3 epoch 0con->rx_seq 2 con->rx_epoch 0
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 2 rx_epoch 0
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 msg=Certificate len=893 seq=2 frag_off=519 frag_len=374
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 Rcvd Certificate in connStatus 0
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 Received unknown(11) in connStatus 0. processing...
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 Certificate can be processed
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 msg_seq:2,msg_len:893,frag_len:374,frag_off: 519
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 Allow: Certificate in status 0
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 Received Certificate in connStatus 0.
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 record length 386
*spamApTask4: Dec 07 13:48:12.480: 00000000: 16 fe fd 00 00 00 00 00 00 00 03 01 82 0b 00 03 ................
*spamApTask4: Dec 07 13:48:12.480: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d1f00, buflen 399
*spamApTask4: Dec 07 13:48:12.488: a0:93:51:76:e2:92 Certificate verification - passed!
*spamApTask4: Dec 07 13:48:12.488: a0:93:51:76:e2:92 Check for bufferred msgs - 0x1a4d1f00(1)
*spamApTask4: Dec 07 13:48:12.488: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d1f00 in status 1
*spamApTask4: Dec 07 13:48:12.488: a0:93:51:76:e2:92 No pending Client Key Exchange in Cert Verify Passed state.
*spamApTask4: Dec 07 13:48:12.488: openssl_shim_info_callback: SSL state = 0x2180; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.488: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:48:12.488: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:48:12.488: openssl_shim_info_callback: SSL_state_string=SSLv3 read client certificate A
*spamApTask4: Dec 07 13:48:12.488: openssl_shim_info_callback: SSL state = 0x2190; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:48:12.488: openssl_shim_info_callback: SSL_state_string=SSLv3 read client key exchange A
*spamApTask4: Dec 07 13:48:12.488: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:48:12.488: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:48:12.488: a0:93:51:76:e2:92 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.488: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:12.488: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 Called... for connection 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 Buffer length 283, alloc_len 287
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=4
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 seq_num 4 epoch 0con->rx_seq 3 con->rx_epoch 0
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 3 rx_epoch 0
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 msg=ClientKeyExchange len=258 seq=3 frag_off=0 frag_len=258
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 Rcvd ClientKeyExchange in connStatus 1
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 Received CLIENT_KEY_EXCHANGE in status 1. processing...
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 ClientKeyExchange can be processed
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 msg_seq:3,msg_len:258,frag_len:258,frag_off: 0
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 Allow: ClientKeyExchange in status 2
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 record length 270
*spamApTask4: Dec 07 13:48:12.489: 00000000: 16 fe fd 00 00 00 00 00 00 00 04 01 0e 10 00 01 ................
*spamApTask4: Dec 07 13:48:12.489: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d1f00, buflen 283
*spamApTask4: Dec 07 13:48:12.704: openssl_shim_info_callback: SSL state = 0x2190; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.704: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:48:12.704: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:48:12.704: openssl_shim_info_callback: SSL_state_string=SSLv3 read client key exchange A
*spamApTask4: Dec 07 13:48:12.704: openssl_shim_info_callback: SSL state = 0x21a0; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:48:12.704: openssl_shim_info_callback: SSL_state_string=SSLv3 read certificate verify A
*spamApTask4: Dec 07 13:48:12.704: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:48:12.705: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d1f00 in status 2
*spamApTask4: Dec 07 13:48:12.705: a0:93:51:76:e2:92 No pending Cert Verify in Client Key Exchange done state.
*spamApTask4: Dec 07 13:48:12.705: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:48:12.705: a0:93:51:76:e2:92 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.848: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:12.848: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.848: a0:93:51:76:e2:92 Called... for connection 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.848: a0:93:51:76:e2:92 Buffer length 285, alloc_len 289
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=5
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 seq_num 5 epoch 0con->rx_seq 4 con->rx_epoch 0
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 4 rx_epoch 0
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 msg=CertificateVerify len=260 seq=4 frag_off=0 frag_len=260
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 Rcvd CertificateVerify in connStatus 2
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 Received CERTIFICATE_VERIFY in connStatus 2. processing...
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 CertificateVerify can be processed
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 msg_seq:4,msg_len:260,frag_len:260,frag_off: 0
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 Allow: CertificateVerify in status 3
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 record length 272
*spamApTask4: Dec 07 13:48:12.849: 00000000: 16 fe fd 00 00 00 00 00 00 00 05 01 10 0f 00 01 ................
*spamApTask4: Dec 07 13:48:12.849: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d1f00, buflen 285
*spamApTask4: Dec 07 13:48:12.855: openssl_shim_info_callback: SSL state = 0x21a0; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.855: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:48:12.855: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:48:12.855: openssl_shim_info_callback: SSL_state_string=SSLv3 read certificate verify A
*spamApTask4: Dec 07 13:48:12.855: openssl_shim_info_callback: SSL state = 0x21c0; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:48:12.855: openssl_shim_info_callback: SSL_state_string=SSLv3 read finished A
*spamApTask4: Dec 07 13:48:12.855: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:48:12.855: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d1f00 in status 3
*spamApTask4: Dec 07 13:48:12.855: a0:93:51:76:e2:92 No Change Cipher Spec pending Cert Verify done state.
*spamApTask4: Dec 07 13:48:12.855: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:48:12.855: a0:93:51:76:e2:92 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.855: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:12.855: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.855: a0:93:51:76:e2:92 Called... for connection 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.855: a0:93:51:76:e2:92 Buffer length 91, alloc_len 95
*spamApTask4: Dec 07 13:48:12.855: a0:93:51:76:e2:92 record=ChangeCipherSpec epoch=0 seq=6
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 seq_num 6 epoch 0con->rx_seq 5 con->rx_epoch 0
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 5 rx_epoch 0
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 Got DTLS_RECORD_CHANGE_CIPHER_SPEC
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 Received CHANGE_CIPHER_SPEC in connStatus 3. processing...
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 DTLS_RECORD_CHANGE_CIPHER_SPEC can be processed
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 record length 1
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 record=Handshake epoch=1 seq=0
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 1
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 updated con with rx_seq_valid 255 rx_seq 0 rx_epoch 1
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 msg=Unknown or Encrypted
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 record length 64
*spamApTask4: Dec 07 13:48:12.856: 00000000: 14 fe fd 00 00 00 00 00 00 00 06 00 01 01 16 fe ................
*spamApTask4: Dec 07 13:48:12.856: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d1f00, buflen 91
*spamApTask4: Dec 07 13:48:12.857: openssl_shim_info_callback: SSL state = 0x21c0; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.857: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:48:12.857: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:48:12.857: openssl_shim_info_callback: SSL_state_string=SSLv3 read finished A
*spamApTask4: Dec 07 13:48:12.857: openssl_shim_info_callback: SSL state = 0x21d0; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.857: openssl_shim_info_callback: SSL_state_string=SSLv3 write change cipher spec A
*spamApTask4: Dec 07 13:48:12.857: openssl_shim_info_callback: SSL state = 0x21e0; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.857: openssl_shim_info_callback: SSL_state_string=SSLv3 write finished A
*spamApTask4: Dec 07 13:48:12.857: openssl_shim_info_callback: SSL state = 0x2100; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:48:12.858: openssl_shim_info_callback: SSL_state_string=SSLv3 flush data
*spamApTask4: Dec 07 13:48:12.858: openssl_shim_info_callback: SSL state = 0x3; where = 0x20; ret = 0x1
*spamApTask4: Dec 07 13:48:12.858: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:48:12.858: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:48:12.858: openssl_shim_info_callback: SSL_state_string=SSL negotiation finished successfully
*spamApTask4: Dec 07 13:48:12.858: openssl_shim_info_callback: SSL state = 0x3; where = 0x2002; ret = 0x1
*spamApTask4: Dec 07 13:48:12.858: a0:93:51:76:e2:92 Connection established!
*spamApTask4: Dec 07 13:48:12.858: a0:93:51:76:e2:92 reset/free pending message buffers
*spamApTask4: Dec 07 13:48:12.858: a0:93:51:76:e2:92 DTLS Connection 0x1a4d1f00 established
*spamApTask4: Dec 07 13:48:12.858: openssl_dtls_mtu_update: Called...
*spamApTask4: Dec 07 13:48:12.858: a0:93:51:76:e2:92 Setting DTLS MTU for link to peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:12.858: a0:93:51:76:e2:92 Sending 91 bytes
*spamApTask4: Dec 07 13:48:12.858: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:48:12.858: a0:93:51:76:e2:92 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.858: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:12.858: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.858: __dtls_timer_stop: Called...
*capwapSocketTask: Dec 07 13:48:12.881: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:48:12.881: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:12.881: a0:93:51:76:e2:92 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.881: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:12.881: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.881: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.883: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:12.883: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.883: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.884: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:12.884: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:12.884: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:13.072: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:48:13.072: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:13.072: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:17.774: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:48:17.774: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:17.774: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:17.775: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:48:17.775: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:17.775: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:22.526: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:48:22.526: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:22.526: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:27.278: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:48:27.278: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:27.278: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:32.030: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:48:32.030: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:32.030: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:36.781: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:48:36.781: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:36.782: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:36.782: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:48:36.782: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:41.533: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:48:41.533: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:41.533: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:46.285: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:48:46.285: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:46.285: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:51.037: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:48:51.037: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*capwapSocketTask: Dec 07 13:48:51.037: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 Called... for connection 0x1a4d1f00
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 Buffer length 61, alloc_len 65
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 record=Alert epoch=1 seq=29
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 handshake_done
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 con->rx_seq_valid 255 con->rx_epoch 1 epoch 1
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 seq_num 29 epoch 1con->rx_seq 0 con->rx_epoch 1
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 con rx_seq_valid 255 rx_seq 0 rx_epoch 1
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 Got DTLS_RECORD_ALERT
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 record length 48
*spamApTask4: Dec 07 13:48:55.790: 00000000: 15 fe fd 00 01 00 00 00 00 00 1d 00 30 e0 e3 b3 ............0...
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 Calling BIO_write! 0x1a4d1f00, buflen 61
*spamApTask4: Dec 07 13:48:55.790: openssl_shim_info_callback: SSL state = 0x3; where = 0x4004; ret = 0x100
*spamApTask4: Dec 07 13:48:55.790: openssl_shim_info_callback: ret_type_string=warning
*spamApTask4: Dec 07 13:48:55.790: openssl_shim_info_callback: ret_desc_string=close notify
*spamApTask4: Dec 07 13:48:55.790: openssl_shim_info_callback: SSL_state_string=SSL negotiation finished successfully
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 SSL_read: peer 10.15.102.11 has closed the connection
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 Requested by openssl_dtls_process_packet
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 in openssl_dtls.c:1032
*spamApTask4: Dec 07 13:48:55.790: 10:b3:d5:3a:81:00 Deleting hash for Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:48:55.791: openssl_shim_info_callback: SSL state = 0x3; where = 0x4008; ret = 0x100
*spamApTask4: Dec 07 13:48:55.791: openssl_shim_info_callback: ret_type_string=warning
*spamApTask4: Dec 07 13:48:55.791: openssl_shim_info_callback: ret_desc_string=close notify
*spamApTask4: Dec 07 13:48:55.791: openssl_shim_info_callback: SSL_state_string=SSL negotiation finished successfully
*spamApTask4: Dec 07 13:48:55.791: 10:b3:d5:3a:81:00 Shutdown completed
*spamApTask4: Dec 07 13:48:55.791: 10:b3:d5:3a:81:00 Sending 61 bytes
*spamApTask4: Dec 07 13:48:55.791: 10:b3:d5:3a:81:00 No data to send
*spamApTask4: Dec 07 13:48:55.791: 10:b3:d5:3a:81:00 DTLS Connection 0x1a4d1f00 closed by controller
*spamApTask4: Dec 07 13:48:55.792: __dtls_timer_stop: Called...
*spamApTask4: Dec 07 13:48:55.792: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d1f00
*spamApTask4: Dec 07 13:48:55.795: dtls_conn_hash_search: Connection not found in hash table - Table empty.
*spamApTask4: Dec 07 13:49:10.997: dtls_conn_hash_search: Connection not found in hash table - Table empty.
*spamApTask4: Dec 07 13:49:10.997: a0:93:51:76:e2:92 Searching hash for Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:10.998: dtls_secret_pki_init: Called...
*spamApTask4: Dec 07 13:49:10.998: dtls_secret_pki_add_idcert: Called...
*spamApTask4: Dec 07 13:49:10.999: acDtlsCallback: Certificate installed for PKI based authentication.
*spamApTask4: Dec 07 13:49:10.999: dtls_timer_start: Called...
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 Called... for connection 0x1a4d20f0
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 Buffer length 160, alloc_len 164
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=0
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 con->rx_seq_valid 0 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 updated con with rx_seq_valid 255 rx_seq 0 rx_epoch 0
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 msg=ClientHello len=135 seq=0 frag_off=0 frag_len=135
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 Rcvd ClientHello in connStatus 0
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 Received unknown(1) in connStatus 0. processing...
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 ClientHello can be processed
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 msg_seq:0,msg_len:135,frag_len:135,frag_off: 0
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 Allow: ClientHello in status 0
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 Received ClientHello in connStatus 0.
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 record length 147
*spamApTask4: Dec 07 13:49:10.999: 00000000: 16 fe ff 00 00 00 00 00 00 00 00 00 93 01 00 00 ................
*spamApTask4: Dec 07 13:49:10.999: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d20f0, buflen 160
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: SSL state = 0x6000; where = 0x10; ret = 0x1
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: SSL_state_string=before/accept initialization
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: SSL state = 0x6000; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: SSL state = 0x2110; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: SSL_state_string=SSLv3 read client hello A
*spamApTask4: Dec 07 13:49:11.000: a0:93:51:76:e2:92 Called...
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: SSL state = 0x2113; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: SSL_state_string=DTLS1 write hello verify request A
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: SSL state = 0x2100; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: SSL_state_string=SSLv3 flush data
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: SSL state = 0x2111; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:49:11.000: openssl_shim_info_callback: SSL_state_string=SSLv3 read client hello B
*spamApTask4: Dec 07 13:49:11.000: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:49:11.000: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d20f0 in status 0
*spamApTask4: Dec 07 13:49:11.000: a0:93:51:76:e2:92 Sending 60 bytes
*spamApTask4: Dec 07 13:49:11.000: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:49:11.000: a0:93:51:76:e2:92 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 Called... for connection 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 Buffer length 192, alloc_len 196
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=1
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 seq_num 1 epoch 0con->rx_seq 0 con->rx_epoch 0
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 0 rx_epoch 0
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 msg=ClientHello len=167 seq=1 frag_off=0 frag_len=167
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 Rcvd ClientHello in connStatus 0
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 Received unknown(1) in connStatus 0. processing...
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 ClientHello can be processed
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 msg_seq:1,msg_len:167,frag_len:167,frag_off: 0
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 Allow: ClientHello in status 0
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 Received ClientHello in connStatus 0.
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 record length 179
*spamApTask4: Dec 07 13:49:11.010: 00000000: 16 fe ff 00 00 00 00 00 00 00 01 00 b3 01 00 00 ................
*spamApTask4: Dec 07 13:49:11.010: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d20f0, buflen 192
*spamApTask4: Dec 07 13:49:11.011: a0:93:51:76:e2:92 Called...
*spamApTask4: Dec 07 13:49:11.011: 00000000: e1 91 98 a2 c3 3d 95 3f ef d7 27 b2 5f c7 69 33 .....=.?..'._.i3
*spamApTask4: Dec 07 13:49:11.011: 00000010: 09 54 ed 0a .T..
*spamApTask4: Dec 07 13:49:11.011: openssl_shim_info_callback: SSL state = 0x2111; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.011: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:49:11.011: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:49:11.011: openssl_shim_info_callback: SSL_state_string=SSLv3 read client hello B
*spamApTask4: Dec 07 13:49:11.011: openssl_shim_info_callback: SSL state = 0x2130; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.011: openssl_shim_info_callback: SSL_state_string=SSLv3 write server hello A
*spamApTask4: Dec 07 13:49:11.012: openssl_shim_info_callback: SSL state = 0x2140; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.012: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:49:11.012: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:49:11.012: openssl_shim_info_callback: SSL_state_string=SSLv3 write certificate A
*spamApTask4: Dec 07 13:49:11.012: openssl_shim_info_callback: SSL state = 0x2160; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.012: openssl_shim_info_callback: SSL_state_string=SSLv3 write certificate request A
*spamApTask4: Dec 07 13:49:11.012: openssl_shim_info_callback: SSL state = 0x2170; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.012: openssl_shim_info_callback: SSL_state_string=SSLv3 write server done A
*spamApTask4: Dec 07 13:49:11.012: openssl_shim_info_callback: SSL state = 0x2100; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.012: openssl_shim_info_callback: SSL_state_string=SSLv3 flush data
*spamApTask4: Dec 07 13:49:11.012: openssl_shim_info_callback: SSL state = 0x2180; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:49:11.012: openssl_shim_info_callback: SSL_state_string=SSLv3 read client certificate A
*spamApTask4: Dec 07 13:49:11.012: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:49:11.012: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d20f0 in status 0
*spamApTask4: Dec 07 13:49:11.012: a0:93:51:76:e2:92 Sending 544 bytes
*spamApTask4: Dec 07 13:49:11.012: a0:93:51:76:e2:92 Sending 333 bytes
*spamApTask4: Dec 07 13:49:11.013: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:49:11.013: a0:93:51:76:e2:92 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.025: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:11.025: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.025: a0:93:51:76:e2:92 Called... for connection 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.025: a0:93:51:76:e2:92 Buffer length 544, alloc_len 548
*spamApTask4: Dec 07 13:49:11.025: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=2
*spamApTask4: Dec 07 13:49:11.025: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:49:11.025: a0:93:51:76:e2:92 seq_num 2 epoch 0con->rx_seq 1 con->rx_epoch 0
*spamApTask4: Dec 07 13:49:11.025: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 1 rx_epoch 0
*spamApTask4: Dec 07 13:49:11.025: a0:93:51:76:e2:92 msg=Certificate len=893 seq=2 frag_off=0 frag_len=519
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 Rcvd Certificate in connStatus 0
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 Received unknown(11) in connStatus 0. processing...
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 Certificate can be processed
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 msg_seq:2,msg_len:893,frag_len:519,frag_off: 0
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 Allow: Certificate in status 0
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 Received Certificate in connStatus 0.
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 record length 531
*spamApTask4: Dec 07 13:49:11.026: 00000000: 16 fe fd 00 00 00 00 00 00 00 02 02 13 0b 00 03 ................
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d20f0, buflen 544
*spamApTask4: Dec 07 13:49:11.026: openssl_shim_info_callback: SSL state = 0x2180; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:49:11.026: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:49:11.026: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:49:11.026: openssl_shim_info_callback: SSL_state_string=SSLv3 read client certificate A
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d20f0 in status 0
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 Called... for connection 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 Buffer length 399, alloc_len 403
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=3
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 seq_num 3 epoch 0con->rx_seq 2 con->rx_epoch 0
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 2 rx_epoch 0
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 msg=Certificate len=893 seq=2 frag_off=519 frag_len=374
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 msg_seq:2,msg_len:893,frag_len:374,frag_off: 519
*spamApTask4: Dec 07 13:49:11.026: a0:93:51:76:e2:92 record length 386
*spamApTask4: Dec 07 13:49:11.027: 00000000: 16 fe fd 00 00 00 00 00 00 00 03 01 82 0b 00 03 ................
*spamApTask4: Dec 07 13:49:11.027: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d20f0, buflen 399
*spamApTask4: Dec 07 13:49:11.034: a0:93:51:76:e2:92 Certificate verification - passed!
*spamApTask4: Dec 07 13:49:11.034: a0:93:51:76:e2:92 Check for bufferred msgs - 0x1a4d20f0(1)
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d20f0 in status 1
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 No pending Client Key Exchange in Cert Verify Passed state.
*spamApTask4: Dec 07 13:49:11.035: openssl_shim_info_callback: SSL state = 0x2180; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.035: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:49:11.035: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:49:11.035: openssl_shim_info_callback: SSL_state_string=SSLv3 read client certificate A
*spamApTask4: Dec 07 13:49:11.035: openssl_shim_info_callback: SSL state = 0x2190; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:49:11.035: openssl_shim_info_callback: SSL_state_string=SSLv3 read client key exchange A
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 Called... for connection 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 Buffer length 283, alloc_len 287
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=4
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 seq_num 4 epoch 0con->rx_seq 3 con->rx_epoch 0
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 3 rx_epoch 0
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 msg=ClientKeyExchange len=258 seq=3 frag_off=0 frag_len=258
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 Rcvd ClientKeyExchange in connStatus 1
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 Received CLIENT_KEY_EXCHANGE in status 1. processing...
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 ClientKeyExchange can be processed
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 msg_seq:3,msg_len:258,frag_len:258,frag_off: 0
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 Allow: ClientKeyExchange in status 2
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 record length 270
*spamApTask4: Dec 07 13:49:11.035: 00000000: 16 fe fd 00 00 00 00 00 00 00 04 01 0e 10 00 01 ................
*spamApTask4: Dec 07 13:49:11.035: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d20f0, buflen 283
*spamApTask4: Dec 07 13:49:11.250: openssl_shim_info_callback: SSL state = 0x2190; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.250: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:49:11.250: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:49:11.250: openssl_shim_info_callback: SSL_state_string=SSLv3 read client key exchange A
*spamApTask4: Dec 07 13:49:11.251: openssl_shim_info_callback: SSL state = 0x21a0; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:49:11.251: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:49:11.251: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:49:11.251: openssl_shim_info_callback: SSL_state_string=SSLv3 read certificate verify A
*spamApTask4: Dec 07 13:49:11.251: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:49:11.251: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d20f0 in status 2
*spamApTask4: Dec 07 13:49:11.251: a0:93:51:76:e2:92 No pending Cert Verify in Client Key Exchange done state.
*spamApTask4: Dec 07 13:49:11.251: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:49:11.251: a0:93:51:76:e2:92 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 Called... for connection 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 Buffer length 285, alloc_len 289
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=5
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 seq_num 5 epoch 0con->rx_seq 4 con->rx_epoch 0
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 4 rx_epoch 0
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 msg=CertificateVerify len=260 seq=4 frag_off=0 frag_len=260
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 Rcvd CertificateVerify in connStatus 2
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 Received CERTIFICATE_VERIFY in connStatus 2. processing...
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 CertificateVerify can be processed
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 msg_seq:4,msg_len:260,frag_len:260,frag_off: 0
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 Allow: CertificateVerify in status 3
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 record length 272
*spamApTask4: Dec 07 13:49:11.387: 00000000: 16 fe fd 00 00 00 00 00 00 00 05 01 10 0f 00 01 ................
*spamApTask4: Dec 07 13:49:11.387: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d20f0, buflen 285
*spamApTask4: Dec 07 13:49:11.394: openssl_shim_info_callback: SSL state = 0x21a0; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.394: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:49:11.394: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:49:11.394: openssl_shim_info_callback: SSL_state_string=SSLv3 read certificate verify A
*spamApTask4: Dec 07 13:49:11.394: openssl_shim_info_callback: SSL state = 0x21c0; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:49:11.394: openssl_shim_info_callback: SSL_state_string=SSLv3 read finished A
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d20f0 in status 3
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 No Change Cipher Spec pending Cert Verify done state.
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 Called... for connection 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 Buffer length 91, alloc_len 95
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 record=ChangeCipherSpec epoch=0 seq=6
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 seq_num 6 epoch 0con->rx_seq 5 con->rx_epoch 0
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 5 rx_epoch 0
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 Got DTLS_RECORD_CHANGE_CIPHER_SPEC
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 Received CHANGE_CIPHER_SPEC in connStatus 3. processing...
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 DTLS_RECORD_CHANGE_CIPHER_SPEC can be processed
*spamApTask4: Dec 07 13:49:11.394: a0:93:51:76:e2:92 record length 1
*spamApTask4: Dec 07 13:49:11.395: a0:93:51:76:e2:92 record=Handshake epoch=1 seq=0
*spamApTask4: Dec 07 13:49:11.395: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 1
*spamApTask4: Dec 07 13:49:11.395: a0:93:51:76:e2:92 updated con with rx_seq_valid 255 rx_seq 0 rx_epoch 1
*spamApTask4: Dec 07 13:49:11.395: a0:93:51:76:e2:92 msg=Unknown or Encrypted
*spamApTask4: Dec 07 13:49:11.395: a0:93:51:76:e2:92 record length 64
*spamApTask4: Dec 07 13:49:11.395: 00000000: 14 fe fd 00 00 00 00 00 00 00 06 00 01 01 16 fe ................
*spamApTask4: Dec 07 13:49:11.395: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d20f0, buflen 91
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: SSL state = 0x21c0; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: SSL_state_string=SSLv3 read finished A
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: SSL state = 0x21d0; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: SSL_state_string=SSLv3 write change cipher spec A
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: SSL state = 0x21e0; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: SSL_state_string=SSLv3 write finished A
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: SSL state = 0x2100; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: SSL_state_string=SSLv3 flush data
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: SSL state = 0x3; where = 0x20; ret = 0x1
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: SSL_state_string=SSL negotiation finished successfully
*spamApTask4: Dec 07 13:49:11.396: openssl_shim_info_callback: SSL state = 0x3; where = 0x2002; ret = 0x1
*spamApTask4: Dec 07 13:49:11.397: openssl_shim_info_callback: SSL_state_string=SSL negotiation finished successfully
*spamApTask4: Dec 07 13:49:11.397: a0:93:51:76:e2:92 Connection established!
*spamApTask4: Dec 07 13:49:11.397: a0:93:51:76:e2:92 reset/free pending message buffers
*spamApTask4: Dec 07 13:49:11.397: a0:93:51:76:e2:92 DTLS Connection 0x1a4d20f0 established
*spamApTask4: Dec 07 13:49:11.397: openssl_dtls_mtu_update: Called...
*spamApTask4: Dec 07 13:49:11.397: a0:93:51:76:e2:92 Setting DTLS MTU for link to peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:11.397: a0:93:51:76:e2:92 Sending 91 bytes
*spamApTask4: Dec 07 13:49:11.397: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:49:11.397: a0:93:51:76:e2:92 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.397: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:11.397: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.397: __dtls_timer_stop: Called...
*capwapSocketTask: Dec 07 13:49:11.420: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:11.420: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:11.420: a0:93:51:76:e2:92 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.420: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:11.420: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.420: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.421: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:11.421: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.421: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.422: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:11.422: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:11.422: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:11.609: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:11.609: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:11.609: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:16.316: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:16.316: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:16.316: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:21.068: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:21.068: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:21.068: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:25.820: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:25.820: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:25.820: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:30.572: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:30.572: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:30.572: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:35.323: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:35.323: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:35.323: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:35.324: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:35.324: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:35.324: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:40.075: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:40.075: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:40.075: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:40.076: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:40.076: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:40.076: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:40.080: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:40.080: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:40.080: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:43.544: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:43.544: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:43.544: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:43.545: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:43.545: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:43.545: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:43.550: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:43.550: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:43.550: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:43.555: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:43.555: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:43.555: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:43.555: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:43.555: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:43.555: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:43.560: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:43.560: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:43.560: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:43.561: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:43.561: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:43.561: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:46.840: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:46.840: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:46.840: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.840: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:46.840: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.840: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.841: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:46.841: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.841: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:46.886: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:46.886: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:46.886: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.887: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:46.887: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.887: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:46.887: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:46.887: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:46.887: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:46.904: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:46.904: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:46.904: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.904: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:46.904: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.905: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.905: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:46.905: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:46.938: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:46.938: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:46.938: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.938: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:46.938: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.938: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.939: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:46.939: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:46.968: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:46.968: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:46.968: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.968: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:46.968: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.968: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.969: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:46.969: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:46.969: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.001: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.001: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.001: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.001: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.001: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.002: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.002: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.002: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.032: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.032: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.032: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.032: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.032: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.032: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.062: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.062: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.062: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.063: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.063: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.063: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.063: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.063: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.063: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.095: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.095: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.095: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.095: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.095: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.096: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.096: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.096: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.129: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.129: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.129: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.129: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.129: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.129: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.159: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.159: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.159: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.159: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.159: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.159: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.160: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.160: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.160: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.189: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.189: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.189: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.189: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.189: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.189: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.190: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.190: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.190: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.315: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.315: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.315: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.315: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.315: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.315: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.439: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.439: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.439: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.439: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.439: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.440: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.440: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.440: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.564: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.564: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.564: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.565: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.565: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.565: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.565: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.565: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.565: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.692: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.692: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.692: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.692: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.693: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.693: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.693: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.693: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.820: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.820: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.820: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.820: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.820: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.820: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.946: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.946: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.946: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.946: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.946: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.946: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.948: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:47.948: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:47.948: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.948: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:47.948: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:47.948: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.073: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.073: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.073: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.073: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.073: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.073: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.074: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.074: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.074: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.074: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.198: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.198: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.198: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.199: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.199: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.199: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.199: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.199: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.199: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.327: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.327: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.327: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.327: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.327: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.327: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.328: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.449: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.449: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.449: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.449: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.449: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.450: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.452: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.452: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.452: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.452: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.452: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.452: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.466: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.466: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.466: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.466: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.466: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.467: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.467: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.467: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.485: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.485: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.485: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.485: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.485: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.485: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.486: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.486: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.486: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.557: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.557: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.557: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.557: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.557: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.557: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.559: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.559: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.559: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.559: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.559: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.560: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.570: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.570: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.570: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.571: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.571: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.571: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.580: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.580: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.580: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.580: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.580: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.580: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.590: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.590: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.590: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.591: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.591: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.591: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.600: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.600: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.600: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.600: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.600: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.600: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.610: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.610: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.610: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.610: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.610: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.610: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.620: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.620: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.620: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.620: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.620: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.620: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.630: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.630: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.630: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.630: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.630: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.630: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.640: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:48.640: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:48.640: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.640: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:48.640: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:48.640: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:51.185: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:49:51.185: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:49:51.185: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:51.186: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:49:51.186: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:49:51.186: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:09.491: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:09.491: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:09.491: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:14.107: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:14.107: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:14.107: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:18.859: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:18.859: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:18.859: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:23.610: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:23.610: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:23.610: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:28.362: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:28.362: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:28.362: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:33.114: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:33.114: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:33.114: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:37.865: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:37.865: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:37.865: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:37.866: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:37.866: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:37.866: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:42.617: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:42.617: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:42.617: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:42.618: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:42.618: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:42.618: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:47.369: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:47.369: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:47.369: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamReceiveTask: Dec 07 13:50:48.447: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamReceiveTask: Dec 07 13:50:48.447: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamReceiveTask: Dec 07 13:50:48.447: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:48.458: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:48.459: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:48.459: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:50:48.459: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:50:48.459: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:50:48.459: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:48.469: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:50:48.469: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*capwapSocketTask: Dec 07 13:50:48.469: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:50:52.121: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:50:52.121: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:50:52.121: 10:b3:d5:3a:81:00 Called... for connection 0x1a4d20f0
*spamApTask4: Dec 07 13:50:52.121: 10:b3:d5:3a:81:00 Buffer length 61, alloc_len 65
*spamApTask4: Dec 07 13:50:52.121: 10:b3:d5:3a:81:00 record=Alert epoch=1 seq=115
*spamApTask4: Dec 07 13:50:52.121: 10:b3:d5:3a:81:00 handshake_done
*spamApTask4: Dec 07 13:50:52.121: 10:b3:d5:3a:81:00 con->rx_seq_valid 255 con->rx_epoch 1 epoch 1
*spamApTask4: Dec 07 13:50:52.121: 10:b3:d5:3a:81:00 seq_num 115 epoch 1con->rx_seq 0 con->rx_epoch 1
*spamApTask4: Dec 07 13:50:52.121: 10:b3:d5:3a:81:00 con rx_seq_valid 255 rx_seq 0 rx_epoch 1
*spamApTask4: Dec 07 13:50:52.121: 10:b3:d5:3a:81:00 Got DTLS_RECORD_ALERT
*spamApTask4: Dec 07 13:50:52.121: 10:b3:d5:3a:81:00 record length 48
*spamApTask4: Dec 07 13:50:52.121: 00000000: 15 fe fd 00 01 00 00 00 00 00 73 00 30 eb ae 73 ..........s.0..s
*spamApTask4: Dec 07 13:50:52.121: 10:b3:d5:3a:81:00 Calling BIO_write! 0x1a4d20f0, buflen 61
*spamApTask4: Dec 07 13:50:52.122: openssl_shim_info_callback: SSL state = 0x3; where = 0x4004; ret = 0x100
*spamApTask4: Dec 07 13:50:52.122: openssl_shim_info_callback: ret_type_string=warning
*spamApTask4: Dec 07 13:50:52.122: openssl_shim_info_callback: ret_desc_string=close notify
*spamApTask4: Dec 07 13:50:52.122: openssl_shim_info_callback: SSL_state_string=SSL negotiation finished successfully
*spamApTask4: Dec 07 13:50:52.122: 10:b3:d5:3a:81:00 SSL_read: peer 10.15.102.11 has closed the connection
*spamApTask4: Dec 07 13:50:52.122: 10:b3:d5:3a:81:00 Requested by openssl_dtls_process_packet
*spamApTask4: Dec 07 13:50:52.122: 10:b3:d5:3a:81:00 in openssl_dtls.c:1032
*spamApTask4: Dec 07 13:50:52.122: 10:b3:d5:3a:81:00 Deleting hash for Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:50:52.122: 10:b3:d5:3a:81:00 Called...
*spamApTask4: Dec 07 13:50:52.122: openssl_shim_info_callback: SSL state = 0x3; where = 0x4008; ret = 0x100
*spamApTask4: Dec 07 13:50:52.122: 10:b3:d5:3a:81:00 Shutdown completed
*spamApTask4: Dec 07 13:50:52.122: 10:b3:d5:3a:81:00 Sending 61 bytes
*spamApTask4: Dec 07 13:50:52.122: 10:b3:d5:3a:81:00 No data to send
*spamApTask4: Dec 07 13:50:52.122: 10:b3:d5:3a:81:00 DTLS Connection 0x1a4d20f0 closed by controller
*spamApTask4: Dec 07 13:50:52.123: __dtls_timer_stop: Called...
*spamApTask4: Dec 07 13:50:52.123: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d20f0
*spamApTask4: Dec 07 13:50:52.124: dtls_conn_hash_search: Connection not found in hash table - Table empty.
*spamApTask4: Dec 07 13:51:07.729: dtls_conn_hash_search: Connection not found in hash table - Table empty.
*spamApTask4: Dec 07 13:51:07.729: a0:93:51:76:e2:92 Searching hash for Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:07.729: dtls_secret_pki_init: Called...
*spamApTask4: Dec 07 13:51:07.729: dtls_secret_pki_add_idcert: Called...
*spamApTask4: Dec 07 13:51:07.731: acDtlsCallback: Certificate installed for PKI based authentication.
*spamApTask4: Dec 07 13:51:07.731: dtls_timer_start: Called...
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 Called... for connection 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 Buffer length 160, alloc_len 164
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=0
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 con->rx_seq_valid 0 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 updated con with rx_seq_valid 255 rx_seq 0 rx_epoch 0
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 msg=ClientHello len=135 seq=0 frag_off=0 frag_len=135
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 Rcvd ClientHello in connStatus 0
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 Received unknown(1) in connStatus 0. processing...
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 ClientHello can be processed
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 msg_seq:0,msg_len:135,frag_len:135,frag_off: 0
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 Allow: ClientHello in status 0
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 Received ClientHello in connStatus 0.
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 record length 147
*spamApTask4: Dec 07 13:51:07.731: 00000000: 16 fe ff 00 00 00 00 00 00 00 00 00 93 01 00 00 ................
*spamApTask4: Dec 07 13:51:07.731: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d22e0, buflen 160
*spamApTask4: Dec 07 13:51:07.731: openssl_shim_info_callback: SSL state = 0x6000; where = 0x10; ret = 0x1
*spamApTask4: Dec 07 13:51:07.731: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:51:07.731: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:51:07.731: openssl_shim_info_callback: SSL_state_string=before/accept initialization
*spamApTask4: Dec 07 13:51:07.731: openssl_shim_info_callback: SSL state = 0x6000; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:07.732: openssl_shim_info_callback: SSL state = 0x2110; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:07.732: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:51:07.732: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:51:07.732: openssl_shim_info_callback: SSL_state_string=SSLv3 read client hello A
*spamApTask4: Dec 07 13:51:07.732: a0:93:51:76:e2:92 Called...
*spamApTask4: Dec 07 13:51:07.732: openssl_shim_info_callback: SSL state = 0x2113; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:07.732: openssl_shim_info_callback: SSL_state_string=DTLS1 write hello verify request A
*spamApTask4: Dec 07 13:51:07.732: openssl_shim_info_callback: SSL state = 0x2100; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:07.732: openssl_shim_info_callback: SSL_state_string=SSLv3 flush data
*spamApTask4: Dec 07 13:51:07.732: openssl_shim_info_callback: SSL state = 0x2111; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:51:07.732: openssl_shim_info_callback: SSL_state_string=SSLv3 read client hello B
*spamApTask4: Dec 07 13:51:07.732: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:51:07.732: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d22e0 in status 0
*spamApTask4: Dec 07 13:51:07.732: a0:93:51:76:e2:92 Sending 60 bytes
*spamApTask4: Dec 07 13:51:07.732: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:51:07.732: a0:93:51:76:e2:92 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 Called... for connection 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 Buffer length 192, alloc_len 196
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=1
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 seq_num 1 epoch 0con->rx_seq 0 con->rx_epoch 0
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 0 rx_epoch 0
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 msg=ClientHello len=167 seq=1 frag_off=0 frag_len=167
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 Rcvd ClientHello in connStatus 0
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 Received unknown(1) in connStatus 0. processing...
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 ClientHello can be processed
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 msg_seq:1,msg_len:167,frag_len:167,frag_off: 0
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 Allow: ClientHello in status 0
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 Received ClientHello in connStatus 0.
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 record length 179
*spamApTask4: Dec 07 13:51:07.742: 00000000: 16 fe ff 00 00 00 00 00 00 00 01 00 b3 01 00 00 ................
*spamApTask4: Dec 07 13:51:07.742: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d22e0, buflen 192
*spamApTask4: Dec 07 13:51:07.742: 00000000: e1 91 98 a2 c3 3d 95 3f ef d7 27 b2 5f c7 69 33 .....=.?..'._.i3
*spamApTask4: Dec 07 13:51:07.742: 00000010: 09 54 ed 0a .T..
*spamApTask4: Dec 07 13:51:07.743: openssl_shim_info_callback: SSL state = 0x2111; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:07.743: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:51:07.743: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:51:07.743: openssl_shim_info_callback: SSL_state_string=SSLv3 read client hello B
*spamApTask4: Dec 07 13:51:07.743: openssl_shim_info_callback: SSL state = 0x2130; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:07.743: openssl_shim_info_callback: SSL_state_string=SSLv3 write server hello A
*spamApTask4: Dec 07 13:51:07.743: openssl_shim_info_callback: SSL state = 0x2140; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:07.743: openssl_shim_info_callback: SSL_state_string=SSLv3 write certificate A
*spamApTask4: Dec 07 13:51:07.743: openssl_shim_info_callback: SSL state = 0x2160; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:07.744: openssl_shim_info_callback: SSL_state_string=SSLv3 write certificate request A
*spamApTask4: Dec 07 13:51:07.744: openssl_shim_info_callback: SSL state = 0x2170; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:07.744: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:51:07.744: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:51:07.744: openssl_shim_info_callback: SSL_state_string=SSLv3 write server done A
*spamApTask4: Dec 07 13:51:07.744: openssl_shim_info_callback: SSL state = 0x2100; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:07.744: openssl_shim_info_callback: SSL_state_string=SSLv3 flush data
*spamApTask4: Dec 07 13:51:07.744: openssl_shim_info_callback: SSL state = 0x2180; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:51:07.744: openssl_shim_info_callback: SSL_state_string=SSLv3 read client certificate A
*spamApTask4: Dec 07 13:51:07.744: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:51:07.744: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d22e0 in status 0
*spamApTask4: Dec 07 13:51:07.744: a0:93:51:76:e2:92 Sending 544 bytes
*spamApTask4: Dec 07 13:51:07.744: a0:93:51:76:e2:92 Sending 333 bytes
*spamApTask4: Dec 07 13:51:07.744: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:51:07.744: a0:93:51:76:e2:92 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 Called... for connection 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 Buffer length 544, alloc_len 548
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=2
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 seq_num 2 epoch 0con->rx_seq 1 con->rx_epoch 0
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 1 rx_epoch 0
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 msg=Certificate len=893 seq=2 frag_off=0 frag_len=519
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 Rcvd Certificate in connStatus 0
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 Received unknown(11) in connStatus 0. processing...
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 Certificate can be processed
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 msg_seq:2,msg_len:893,frag_len:519,frag_off: 0
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 Allow: Certificate in status 0
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 Received Certificate in connStatus 0.
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 record length 531
*spamApTask4: Dec 07 13:51:07.755: 00000000: 16 fe fd 00 00 00 00 00 00 00 02 02 13 0b 00 03 ................
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d22e0, buflen 544
*spamApTask4: Dec 07 13:51:07.755: openssl_shim_info_callback: SSL state = 0x2180; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:51:07.755: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:51:07.755: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:51:07.755: openssl_shim_info_callback: SSL_state_string=SSLv3 read client certificate A
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d22e0 in status 0
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:51:07.755: a0:93:51:76:e2:92 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 Called... for connection 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 Buffer length 399, alloc_len 403
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=3
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 seq_num 3 epoch 0con->rx_seq 2 con->rx_epoch 0
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 2 rx_epoch 0
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 msg=Certificate len=893 seq=2 frag_off=519 frag_len=374
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 Rcvd Certificate in connStatus 0
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 Received unknown(11) in connStatus 0. processing...
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 Certificate can be processed
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 msg_seq:2,msg_len:893,frag_len:374,frag_off: 519
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 Allow: Certificate in status 0
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 Received Certificate in connStatus 0.
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 record length 386
*spamApTask4: Dec 07 13:51:07.756: 00000000: 16 fe fd 00 00 00 00 00 00 00 03 01 82 0b 00 03 ................
*spamApTask4: Dec 07 13:51:07.756: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d22e0, buflen 399
*spamApTask4: Dec 07 13:51:07.764: a0:93:51:76:e2:92 Certificate verification - passed!
*spamApTask4: Dec 07 13:51:07.764: a0:93:51:76:e2:92 Check for bufferred msgs - 0x1a4d22e0(1)
*spamApTask4: Dec 07 13:51:07.764: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d22e0 in status 1
*spamApTask4: Dec 07 13:51:07.764: a0:93:51:76:e2:92 No pending Client Key Exchange in Cert Verify Passed state.
*spamApTask4: Dec 07 13:51:07.764: openssl_shim_info_callback: SSL state = 0x2180; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:07.764: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:51:07.764: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:51:07.764: openssl_shim_info_callback: SSL_state_string=SSLv3 read client certificate A
*spamApTask4: Dec 07 13:51:07.764: openssl_shim_info_callback: SSL state = 0x2190; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:51:07.764: openssl_shim_info_callback: SSL_state_string=SSLv3 read client key exchange A
*spamApTask4: Dec 07 13:51:07.764: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:51:07.764: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:51:07.764: a0:93:51:76:e2:92 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.764: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:07.764: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.764: a0:93:51:76:e2:92 Called... for connection 0x1a4d22e0
*spamApTask4: Dec 07 13:51:07.764: a0:93:51:76:e2:92 Buffer length 283, alloc_len 287
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=4
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 seq_num 4 epoch 0con->rx_seq 3 con->rx_epoch 0
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 3 rx_epoch 0
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 msg=ClientKeyExchange len=258 seq=3 frag_off=0 frag_len=258
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 Rcvd ClientKeyExchange in connStatus 1
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 Received CLIENT_KEY_EXCHANGE in status 1. processing...
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 ClientKeyExchange can be processed
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 msg_seq:3,msg_len:258,frag_len:258,frag_off: 0
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 Allow: ClientKeyExchange in status 2
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 record length 270
*spamApTask4: Dec 07 13:51:07.765: 00000000: 16 fe fd 00 00 00 00 00 00 00 04 01 0e 10 00 01 ................
*spamApTask4: Dec 07 13:51:07.765: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d22e0, buflen 283
*spamApTask4: Dec 07 13:51:07.980: openssl_shim_info_callback: SSL state = 0x2190; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:07.980: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:51:07.980: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:51:07.980: openssl_shim_info_callback: SSL_state_string=SSLv3 read client key exchange A
*spamApTask4: Dec 07 13:51:07.980: openssl_shim_info_callback: SSL state = 0x21a0; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:51:07.980: openssl_shim_info_callback: SSL_state_string=SSLv3 read certificate verify A
*spamApTask4: Dec 07 13:51:07.980: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:51:07.980: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d22e0 in status 2
*spamApTask4: Dec 07 13:51:07.980: a0:93:51:76:e2:92 No pending Cert Verify in Client Key Exchange done state.
*spamApTask4: Dec 07 13:51:07.980: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:51:07.980: a0:93:51:76:e2:92 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 Called... for connection 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 Buffer length 285, alloc_len 289
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 record=Handshake epoch=0 seq=5
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 seq_num 5 epoch 0con->rx_seq 4 con->rx_epoch 0
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 4 rx_epoch 0
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 msg=CertificateVerify len=260 seq=4 frag_off=0 frag_len=260
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 Rcvd CertificateVerify in connStatus 2
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 Received CERTIFICATE_VERIFY in connStatus 2. processing...
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 CertificateVerify can be processed
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 local_openssl_dtls_handshake_replay_detection:
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 msg_seq:4,msg_len:260,frag_len:260,frag_off: 0
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 Allow: CertificateVerify in status 3
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 record length 272
*spamApTask4: Dec 07 13:51:08.111: 00000000: 16 fe fd 00 00 00 00 00 00 00 05 01 10 0f 00 01 ................
*spamApTask4: Dec 07 13:51:08.111: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d22e0, buflen 285
*spamApTask4: Dec 07 13:51:08.117: openssl_shim_info_callback: SSL state = 0x21a0; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:08.117: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:51:08.117: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:51:08.117: openssl_shim_info_callback: SSL_state_string=SSLv3 read certificate verify A
*spamApTask4: Dec 07 13:51:08.117: openssl_shim_info_callback: SSL state = 0x21c0; where = 0x2002; ret = 0xffffffff
*spamApTask4: Dec 07 13:51:08.117: openssl_shim_info_callback: SSL_state_string=SSLv3 read finished A
*spamApTask4: Dec 07 13:51:08.117: a0:93:51:76:e2:92 Handshake in progress... check for bufferred msgs
*spamApTask4: Dec 07 13:51:08.117: a0:93:51:76:e2:92 checkAndHandleBufferredMsgs called for con 0x1a4d22e0 in status 3
*spamApTask4: Dec 07 13:51:08.117: a0:93:51:76:e2:92 No Change Cipher Spec pending Cert Verify done state.
*spamApTask4: Dec 07 13:51:08.117: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:51:08.117: a0:93:51:76:e2:92 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 Called... for connection 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 Buffer length 91, alloc_len 95
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 record=ChangeCipherSpec epoch=0 seq=6
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 0
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 seq_num 6 epoch 0con->rx_seq 5 con->rx_epoch 0
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 con rx_seq_valid 255 rx_seq 5 rx_epoch 0
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 Got DTLS_RECORD_CHANGE_CIPHER_SPEC
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 Received CHANGE_CIPHER_SPEC in connStatus 3. processing...
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 DTLS_RECORD_CHANGE_CIPHER_SPEC can be processed
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 record length 1
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 record=Handshake epoch=1 seq=0
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 con->rx_seq_valid 255 con->rx_epoch 0 epoch 1
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 updated con with rx_seq_valid 255 rx_seq 0 rx_epoch 1
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 msg=Unknown or Encrypted
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 record length 64
*spamApTask4: Dec 07 13:51:08.118: 00000000: 14 fe fd 00 00 00 00 00 00 00 06 00 01 01 16 fe ................
*spamApTask4: Dec 07 13:51:08.118: a0:93:51:76:e2:92 Calling BIO_write! 0x1a4d22e0, buflen 91
*spamApTask4: Dec 07 13:51:08.119: openssl_shim_info_callback: SSL state = 0x21c0; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:08.119: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:51:08.119: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:51:08.119: openssl_shim_info_callback: SSL_state_string=SSLv3 read finished A
*spamApTask4: Dec 07 13:51:08.119: openssl_shim_info_callback: SSL state = 0x21d0; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:08.119: openssl_shim_info_callback: SSL_state_string=SSLv3 write change cipher spec A
*spamApTask4: Dec 07 13:51:08.120: openssl_shim_info_callback: SSL state = 0x21e0; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:08.120: openssl_shim_info_callback: ret_type_string=unknown
*spamApTask4: Dec 07 13:51:08.120: openssl_shim_info_callback: ret_desc_string=unknown
*spamApTask4: Dec 07 13:51:08.120: openssl_shim_info_callback: SSL_state_string=SSLv3 write finished A
*spamApTask4: Dec 07 13:51:08.120: openssl_shim_info_callback: SSL state = 0x2100; where = 0x2001; ret = 0x1
*spamApTask4: Dec 07 13:51:08.120: openssl_shim_info_callback: SSL_state_string=SSLv3 flush data
*spamApTask4: Dec 07 13:51:08.120: openssl_shim_info_callback: SSL state = 0x3; where = 0x20; ret = 0x1
*spamApTask4: Dec 07 13:51:08.120: openssl_shim_info_callback: SSL_state_string=SSL negotiation finished successfully
*spamApTask4: Dec 07 13:51:08.120: openssl_shim_info_callback: SSL state = 0x3; where = 0x2002; ret = 0x1
*spamApTask4: Dec 07 13:51:08.120: a0:93:51:76:e2:92 Connection established!
*spamApTask4: Dec 07 13:51:08.120: a0:93:51:76:e2:92 reset/free pending message buffers
*spamApTask4: Dec 07 13:51:08.120: a0:93:51:76:e2:92 DTLS Connection 0x1a4d22e0 established
*spamApTask4: Dec 07 13:51:08.120: openssl_dtls_mtu_update: Called...
*spamApTask4: Dec 07 13:51:08.120: a0:93:51:76:e2:92 Setting DTLS MTU for link to peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:08.120: a0:93:51:76:e2:92 Sending 91 bytes
*spamApTask4: Dec 07 13:51:08.120: a0:93:51:76:e2:92 No data to send
*spamApTask4: Dec 07 13:51:08.120: a0:93:51:76:e2:92 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.120: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:08.120: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.120: __dtls_timer_stop: Called...
*capwapSocketTask: Dec 07 13:51:08.144: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:08.144: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:08.144: a0:93:51:76:e2:92 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.146: a0:93:51:76:e2:92 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:08.146: a0:93:51:76:e2:92 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.146: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.147: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:08.147: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.147: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.148: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:08.148: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.148: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.149: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:08.149: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:08.149: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:08.334: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:08.334: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:08.334: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:13.051: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:13.051: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:13.051: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:17.803: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:17.803: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:17.803: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:22.554: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:22.554: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:22.554: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:22.555: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:22.556: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:22.556: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:22.556: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:22.560: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:22.560: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:22.560: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:26.013: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:26.013: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:26.013: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:26.013: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:26.014: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:26.018: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:26.018: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:26.019: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:26.023: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:26.023: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:26.023: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:26.024: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:26.024: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:26.024: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:26.029: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:26.029: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:26.029: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:26.029: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:26.029: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:26.030: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.304: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:29.304: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.304: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.305: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:29.305: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.305: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.306: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:29.306: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.306: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.348: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:29.348: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.348: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.348: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:29.348: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.348: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.349: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:29.349: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.349: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.368: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:29.368: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.368: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.368: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:29.368: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.368: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.400: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:29.400: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.400: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.401: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:29.401: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.401: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.401: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:29.401: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.401: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.402: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:29.402: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.402: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.432: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:29.432: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.432: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.433: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:29.433: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.433: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.463: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:29.463: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.463: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.463: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:29.463: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.464: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.464: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:29.464: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.496: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*capwapSocketTask: Dec 07 13:51:29.496: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*capwapSocketTask: Dec 07 13:51:29.496: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.496: 10:b3:d5:3a:81:00 DTLS connection find by 0x10e7908c with Local 10.15.152.5:5246 Peer 10.15.102.11:5272
*spamApTask4: Dec 07 13:51:29.497: 10:b3:d5:3a:81:00 DTLS connection found! Acquiring lock for 0x1a4d22e0
*spamApTask4: Dec 07 13:51:29.497: 10:b3:d5:3a:81:00 Releasing lock for 0x1a4d22e0
Hello MHM,
mDNS Global Snooping is disabled globally on the 4 WLCs. At WLC-2 I saw 2 more services than the other WLCs. So I deleted them and reset the ap. Unsuccessfully. The report suggests deleting the files but I did not understand how to execute them in practice. This is the show flash:
AP084F.A9E9.0A84#show flash
Directory of /storage/
total 144
-rw-r--r-- 1 root root 3 Dec 8 13:29 BOOT_COUNT
-rw-r--r-- 1 root root 3 Dec 8 13:29 BOOT_COUNT.reserve
-rw-r--r-- 1 root root 28 Dec 8 13:29 RELOADED_AT_UTC
drwxr-xr-x 3 root root 224 Dec 8 13:30 application
-rw-r--r-- 1 root root 38090 Dec 8 13:48 base_capwap_cfg_info
-rw-r--r-- 1 root root 20 Dec 7 21:13 bigacl
-rw-r--r-- 1 root root 0 Nov 27 2019 bootloader.log
-rw-r--r-- 1 root root 5 Dec 5 13:51 bootloader_verify.shadow
-rw-r--r-- 1 root root 18 Dec 7 18:45 config
-rw-r--r-- 1 root root 41276 Dec 8 13:45 config.flex
-rw-r--r-- 1 root root 0 Dec 8 13:37 config.flex.mgroup
-rw-r--r-- 1 root root 0 Dec 8 13:29 config.local
-rw-r--r-- 1 root root 394 Dec 8 13:30 config.mobexp
-rw-r--r-- 1 root root 2014 Dec 8 13:45 config.wireless
drwxr-xr-x 2 root root 160 Nov 28 2019 cores
drwxr-xr-x 2 root root 320 Nov 28 2019 dropbear
-rw-r--r-- 1 root root 254 Dec 1 19:11 last_good_uplink_config
drwxr-xr-x 2 root root 160 Nov 27 2019 lists
-rw-r--r-- 1 root root 63 Dec 1 19:10 part1_info.ver
-rw-r--r-- 1 root root 63 Sep 24 17:05 part2_info.ver
-rw-r--r-- 1 root root 4096 Dec 8 13:36 random_seed
-rw-r--r-- 1 root root 3 Nov 28 2019 rxtx_mode
-rw-r--r-- 1 root root 64 Dec 8 13:30 sensord_CSPRNG0
-rw-r--r-- 1 root root 64 Dec 8 13:30 sensord_CSPRNG1
drwxr-xr-x 3 support root 224 Nov 27 2019 support
drwxr-xr-x 2 root root 2200 Dec 8 13:30 syslogs
Filesystem Size Used Available Use% Mounted on
flash 57.5M 328.0K 54.2M 1% /storage
the bug detail and workaround to mention which file must be to delete but we can rest one AP to factory.
and try rejoin rest is same as delete the AP file.
hope this work.
Hello MHM,
already did reset but not solved. Yesterday we took (again) the switch and APs to another site and everything worked. I saw a difference: On the defective site, the switch shows a flood of MD5 events in the logging. When I connect the same switch to the other site, the events do not occur.
However, we already replaced the router on the defective site and I was not successful, MD5 errors persist (I already changed the trunk cable). I believe this flood of MD5 events would be overloading the switch's processing and memory, affecting the APs' joining process.
This is the event:
% TCP-6-BADAUTH: No MD5 digest from 10.x.x.x (65xxx) to 10.x.x.x (65xxx)
Today I will try to solve this issue. The wan team continues to analyze L3 and transmission layer.
Tks
10.x.x.x (65xxx) to 10.x.x.x (65xxx) <- are they same ip and tcp port?
if yes then you config HTTP server in router and server/router ping it self.
this is the real log ( a lot of...):
Dec 10 13:59:09.958 BRZ: %TCP-6-BADAUTH: No MD5 digest from 10.15.102.1(64999) to 10.15.102.10(51385) (RST) tableid - 0
Dec 10 13:59:09.961 BRZ: %TCP-6-BADAUTH: No MD5 digest from 10.15.102.1(64999) to 10.15.102.10(51385) (RST) tableid - 0
Dec 10 13:59:12.586 BRZ: %TCP-6-BADAUTH: No MD5 digest from 10.15.102.1(64999) to 10.15.102.10(51385) (RST) tableid - 0
Dec 10 13:59:15.333 BRZ: %TCP-6-BADAUTH: No MD5 digest from 10.15.102.1(64999) to 10.15.102.10(11011) (RST) tableid - 0
Dec 10 13:59:17.836 BRZ: %TCP-6-BADAUTH: No MD5 digest from 10.15.102.1(64999) to 10.15.102.10(51385) (RST) tableid - 0
Dec 10 13:59:19.332 BRZ: %TCP-6-BADAUTH: No MD5 digest from 10.15.102.1(64999) to 10.15.102.10(19603) (RST) tableid - 0
I think about one solution but I don't know if it work or not if this happened because of latency of WAN, enable link latency and increase AP heartbeat timeout.
please if you can share link latency.
