Catalyst 9115AXI-E mesh function
dlangohr
Community Member
we are using several 9115AXI-E Access Points. One of the 9115AXI-E are running as a Embedded Wireless Lan Controller.
We installed the latest firmware version. 17.11
We like to build a mesh network. Is it possible to configure a functionally mesh with the 9115AXI-E Accesspoints?
In the Documentation of Cisco I found only that it is possible with the 9124AX Accesspoint as Embedded WLC.
Does anyone try to use mesh with the 9115AXI-E?
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-6/config-guide/ewc_cg_17_6/mesh_access_points.html#Cisco_Concept.dita_a238aeab-face-4371-a6f2-cca2887b7294
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
