Catalyst 9800-L-F fans failed after upgrade
ppnlr
After upgrading the 9800 from 17.9.4a to 17.9.5 an error appears:
*Sep 10 13:08:16.163: %CMRP_PFU-3-PFU_FANS_DEAD: Chassis 1 R0/0: cmand: The fans in the FM in slot 1 have all failed.
upon observation, I think the fans stopped, although if the device reloads, you will hear it running. I'm trying to rollback the version but I think the device reloads due to excessive heat.
7 Replies 7
ammahend
share
show facility-alarm status
-hope this helps-
  - You may also look into :
           show platform software system all
            show platform resources
            show environment chassis active r0
           show environment
           show environment summary
 M.
marce1000
    - May I also add :
               show logging profile hardware-diagnostics
                 show platform hardware slot 0 fan status
                 show platform hardware slot P1 fan status
  M.
ppnlr
I just turned off the device to cool down..then turn it on again and the error didn't reappear. tried to upgrade the software again just in case that's a bug.
         >.....then turn it on again and the error didn't reappear.
  - Note that even in that case it can be useful to checkout the health of the controller
    Advised commands :     show facility-alarm status
  M.
ppnlr
just ran the commands today and everything is normal. Thanks for the assisstance.
   - Great to hear !
 M.
