CB21AG adapter reauthentication problem
eenciso
Community Member
I upgraded to from CB20A to CB21AG and I'm having problems with reauthentication with my Cisco AP1200. After 2 days, connection/static IP get drop and unable to authenticate without rebooting notebook.
scottmac
Level 11
Level 11
What version of firmware are you running in the AP?
What version of client software are you running?
Update both and see if that helps.
Good Luck
Scott
eenciso
Community Member
System software version in the AP1200 is 12.3(7)JA1, bootloader version:12.2(8)JA
As for the client adapter, I installed the latest, 2.5.
I am also running only tkip-wep128bit cipher, I have a wireless printer that only support wep.
I checked and double checked all setting in the client adapter and AP.
