cb21ag card problems
jcosgrove
Level 4
Level 4
I seem to have noticed the following in reguard to the cb21ag.
Slow scanning...tends to stick with bad ap and not roam to another/better AP.
Not able to use the Cisco Conf utility for any authentication besides leap on XP. To use WPA/TKIP with PEAP or any PEAP I need to employ the windows XP Zero wireless configuration.
Too little config options in the base drivers. Would like to be able to disable the 802.11A scanning without having to load the full Cisco Config utility.
Does not seem to work with client walkabout with the WLSE.
Has anyone else seen problems like these? Does anyone know whan the next round of drivers is due out and what it will be fixing/adding?
Please share your experiences.
JC
ejaakola
Community Member
We are having problems with CB21AG cards and WLSE 2.7 client walkabout too. Radio scan goes through nicely but when client walkabout starts no data is received or saved by the wlse.
What card are you using for walkabout, if any?
I see the same problem with the CB21AG. I seem to have no problem with the 350b card. Another problem I am having is using the RM assisted configuration. When I set it up to configure 2 or 3 AP's no problem. When I tell it about all 125 AP's I have in my building it starts calculating but never gets anywhere. Stays at zero percent complete.
JC
Could someone from Cisco comment on this card issue? Does the CB21AG card work with WLSE 2.7 client walkabout or not?
Esa
