05-08-2021 01:37 PM - edited 07-05-2021 01:17 PM
i am using the Ethernet-ports of a 145ac.
Connecting with Ethernet cable the small led is blinking orange (or should it be yellow) and everything is working fine, also if VLAN is configurated. But sometime, connected with some clients, there is additionally a small green led on (I do not meen the main led of the AP, i mean this 2 small leds left and right of each lan port), and everytime this led is on or blinking, the connection to the client is down.
So my question is, what is the functionality of each of this both led?
Thanks.
Tom
05-08-2021 02:30 PM
can you get the picture and upload here to understand the status or look below guide LED status :
05-08-2021 11:28 PM
Thanks for the link, but in these tables i only can find the describtion of the behavior of the main led from the AP and not the leds on the side of each of the 3 LAN ports. I miss the description of the leds for their 'switch function', at least I can't find that in the manual.
05-09-2021 01:49 AM
post the picture to understand as mentioned earlier.
05-09-2021 02:16 AM
these are the 2 the led's i mean (red bordered):
if a client is connectet the yellow one is blinking slowly - everything is working fine.
in some cases, a client is connected and the green one flashes additionally, and client dont't have access to my router.
So if i would know, what the functionality of the green led is, i hopefully can isolate the error better.
05-09-2021 05:11 AM
I have not used this device, most cisco device
Green Flashing means working.
Organge blinking - may be duplex or speed mismatch or try to negotiate.
you can view the logs in the device.
05-13-2021 12:18 AM - edited 05-13-2021 08:39 AM
In the manual of the Cisco Aironet 1815w (which seems to be identically in construction to the 145ac) i found a description of the statuses of these ethernet leds:
But interesstingly the leds on my 145ac the are lighting up the other way round.
If my different notebooks (f.e. thinkpad T14, dell 5401, ... ) are connected, the green LED isn't lighting up (but the notebooks are working with the rigth GBit-connection-speed in this case), but if some device are connected which have definitly no GBit/s network-card, the green LED is on.
So maybe the functinallity from the Aironet 1815 to the 145ac has been changed, or there is an other reason or bug that can explain this behavior.
