CCX Radio Management
serotonin888
I noticed this feature is disabled by default.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_010000111.html
Are there any issues in enabling it? Looks like it might add a small amount of additional traffic to the WLAN.
Looks fairly safe to enbale but always worth a 2nd opinion.
Thanks in advance
Saurav Lodh
Level 7
Level 7
It doesn't create burden on WLANs as you can see
" To prevent the access points and Cisco WLC from being overwhelmed by radio measurement requests and reports, only two clients per access point and up to 20 clients per Cisco WLC are supported."
Saurav Lodh
Level 7
Level 7
