03-10-2004 12:45 PM - edited 07-04-2021 09:26 AM
Is there any benefit to turning on CDP for the radio interface?
03-16-2004 04:16 PM
Well I do not think you get any major benefits other then identifying the parameters set on the wireless device to which the radio interface is connected to. In case if you are running any VLANs on the AP it's better you disable CDP on the radio interface.
10-24-2013 10:23 AM
For best performance on your wireless LAN, disable CDP on all radio interfaces and on sub-interfaces if VLANs are enabled on the access point.
Source ::
