CDP radio interface
francois.beaunoyer
Community Member
I use two 1310 aironet access point, the 1st link to my network by the ethernet interface is a root bridge and the other is a non root bridge. I'm using Cisco Works LMS to monitor my network. Right now i can see the root bridge in my map but i can't see the non root bridge. All the settings for CDP are enable on each interface on both access point. For best result i know that Cisco recommends to disable CDP on the radio interface but right now i am doing test and i will really appreciate to see the non root bridge in my map.
Is there anyone who have clues for me.
ebreniz
Level 11
Level 11
Make sure the interfaces are working on the non-root bridges for which it is not working.
