10-17-2011 12:38 AM - edited 07-03-2021 08:56 PM
HI Friends
I am using wireless system with certificate athentication ( CA Server ) and RADIUS server.
I want to know if certificate is not installed and configured in wireless client laptop.
Do client get athenticate in wireless system and get access of wireless network ?
Also want to know any configuration required in WLC CISCO 4402 for authentication with CA server of client laptop.
10-17-2011 05:40 AM
that depends on what EAP types you are allowing. If you only allow EAP-TLS, and the client doesn't have their user or machine certificate, then no they will not be allowed on.
In the case of PEAP, the client having the certificate is not required. So if the supplicant was told to not validate the server certificate, they could still get on the network.
HTH,
Steve
10-17-2011 07:02 AM
Thanks for reply.
Please guide me for below queries.
1. What configuration has to be done on wireless client for certificate authentication
2. What configuration has to be done on Cisco 4402 Wireless controller
3. Which Radius as well as CA server has to be used for Certificate authentication
As well as what type of Wireless configuration need to be change in Wireless setup.
