Change ACS 5 SSL Certificate for web admin?
Can you use your own SSL certificate on an ACS 5 server?
I have loaded an SSL certificate from my CA onto my ACS 5 eval server, and have selected it in the ACS admin screen as the cert to use for EAP and HTTPS. However, it is not being used for the web admin interface (the self-cert is still being used). Looking at the ACS 5 user guide, I see the following text, which makes me think you cannot change the cert used for ACS browser-based admin (despite the typo/confusing wording):
"A default Local Certificate server is installed on ACS so that you can connect to ACS with your browser. You cannot configure of modify the ACS server that is provided during installation."
Lucien Avramov
Level 10
Level 10
there is an internal defect found during recent testing.
you are correct, it does not work but it should.
It will be fixed in ACS 5.1.
If you need this defect to be made external so you can view it, please open a TAC case.
There are no workarounds, you need to wait for ACS 5.1
