Change duplex and speed AP lightweight
When o Access Point was in Autonomous, the interface was "state up protocol down" in "show int g0", so I change manually speed/duplex (100/full) and was "state up protocol up", so converting the Access Point from Autonomous to Lightweight and happened the same problem ("state up protocol down")!
What command for configure speed/duplex in interface when Access Point is mode Lightweight?
7 Replies 7
Leo Laohoo
The interface of the AP should never be re-configured, autonomous or controller-based setup.
Check your switch, make sure the interface settings at the switch port is auto/auto.
Sandeep Choudhary
adding to Leo :)
First login to AP by username and password.
Command for LAP to change speed/duplex
Config t
Int fa0 or int Gi0
speed 100
duplex full
Dont forget to rate helpful posts
abwahid
Level 4
Level 4
Change you switch port which is connected to Access-point to full duplex speed
as far as i know we can not change the LWAP switchport to forcely full duplex.
It's Switch not management!
Thanks for attention!
This command enable "conf t" in Access Point is mode Lightweigh:
debug capwap console cli
enabled once you enter the interface and change:
Config t
int Gi0
speed 100
duplex full
Problem Solved!!!!!!!!!
Thanks for the one-star rating, Claudio.  :P
By the way, your solution of setting the interface and the speed (on the AP) is just temporary measure.  The minute you reboot your AP your problem will return.   Why do you think all of us who's recommending the solution is focusing on the switch?
mariosalvador
can't change wired 0 in 4800. only changes can be done at the uplink switch
